I was reading another thread about different management set ups and read something interesting about knock maps. It was suggested that while nistune retains the standard knock maps, other systems like power fc do not, even though they display a knock reading.
I would like to know if this is correct. Would this mean those running power fc have essentially done away with the rich and retartd function as result?
Also do other systems like microtec use any kind of knock detection, R+R, or just a waring sytem?
cheers..........
https://www.sau.com.au/forums/topic/327720-knock-map-question/
no, R+R is simply the higher airflow end of the map. from factory both the normal and knock maps are hugely rich and retarded towards the end of the map wit the knock map obviously being more retarded than the normal map.
power fc's have no form of knock control whatsoever, they run whatever timing is on the map and simply flash a number if one of the knock sensors picks up something.
nistune uses the factory system, with a normal map and a knock map. will run off the normal map until knock is deteced, then it'll switch over to knock maps. if the knock map is too advanced then it'll keep knocking, it wont pull out any more timing. so you have to set it up rather conservatively.
pretty sure vipecs have true knock control, retarding timing until theres no more knock, this is the safest way
AEM version 2 has the best knock map-style functionality ive seen so far, VIPEC and LINK have an ok system it as do the new Haltech's and most MOTEC (once enabled) so its not really an issue if you want it as most decent ecu's support it.
The NISTUNE setup is pretty cool and very easy to setup on your basic std engine but like all knock systems becomes harder once the engine and car become more modified, clutch choice, engine clearances and lash type can all play havoc with the knock sensors which require recalibrating to the "new noise" introduced with such modifications.
Thanks guys that explains r&r a lot better for me.
I need to understand it better as i am trying to figure out the most inexpensive way to get more mid range out of my r33, as it seems to be a bit doughy before 5000rpm. I thought it might have been running knock maps in that region and i was considering padding out the sensors with resistors as a tuner told me the car is not knocking but was being retarded by my overly sensitive sensors? But now it seems that i may also have an issue simply with the r&r end of the normal map.
I have the usual basic mods including a high flow turbo (hypergear) and a safcs2 as my only form of tuning. I have checked my vvt solinoid is ok and it seems to be. I know high flow turbos are slightly bigger, but i would not have thought that they would sacrafice so much mid range over standard.
The car has only had one breif tune and made 275hp at 6000rpm (11psi) which is all well and good but it has nothing prior to 5000rpm. Funnily enough if i only use half throttle it seems to be far more responsive in the midrange and goes about as hard as full throttle? Any suggestions? Cheers......
Ps. i have not yet put in adjustable fuel reg. Perhaps this would help tune out R&R with safcs ?
Issue is the big drop in timing in the factory tune, you will need either a remap or a new tunable ecu.
Have a look at the timing numbers in this R33 map from 4800rpm onwards load areas 72-on (timing drops from 20 to 16 which is around 20kw in one fatal swoop. Thats why part throttle (lower load) will actually make more power as it will run along load point 56 which has 26 degrees :P Nissan aint stupid they know exactly what goes on once the car leaves the showroom.... call it built in safety..
http://www.skylinesaustralia.com/forums/post-a284940-
is that a 100% stock map? nice little jump from 16 to 53 degrees up the top
also interesting how much timing they drop right around where the stock turbo hits full boost
This is why nistune is such a brilliant way to get a completely tuneable ECU, cheap and it has more features than most aftermarket ECUs.
The reason I imagine the map does that is because when 100% standard the car most likely runs only along 75% of the map, then when it gets modified you run up to the rest of the cells, because nissan assumed that this was because someone had slapped a dirty big turbo on it they retard the ignition immensely to prevent damage, however during normal driving with a stock setup the ECU would never reach those cells.
Edited by Rolls
i would have thought that standard or not, the entire map would be used because the load points appear to be throttle position reference points. so if you are foot flat and towards the end of the rpm range you will find your self in the least desirable end of the map regardless of modifications or not.
The load axis is theoretical pulsewidth (based on maf voltage and injector constant) not throttle position.
Don't let the knock feature of the factory system sway your judgement when selecting an ecu as it's quiet poor and will usually only revert to the lower octane map if you see lots of knock at low rpm high load. That being said I'm a big fan of the factory system compared to most other aftermarket ecus.
the part i'm talking about is very light load, off boost. turbo size would be irrelevant. you could reach those sells parked in your driveway if you wanted
Correct (i agree wholly) and to add to that the factory system only has closed loop knock control to around 4000rpm (model specific) so if you find it is reliable you can raise it via nistune.
The only way to reach the cells you talk of are to rev your car to redline and quickly let off the accel and coast ie above 5200 rpm with no load and it will only pass through there on the way back to idle, soon as you add any throttle it will be out of there in an instant.
So in theory if you could some how cap the voltage signal from the afm so that you eliminated a few of the high end load reference points, and use a fuel reg to replace the lost fuel, although crude, you would at least have improved timming without the expence of an after market computer? I relise it would not be as good, but would it work? Obviously it would be subject to a safe tune!
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
