Ok, getting the car fully detailed on tuesday and i wanna take some nice pix while the car is still looking spico
anybody got any suggestions for nice back drop locations around brissy?
ill probably just go down to the cliffs at kangaroo point, but im open to suggestions if anybody knows anywhere else nice that could be a backdrop to my car
https://www.sau.com.au/forums/topic/32777-scenic-backdrops/
um choas and nismoman18 went to some hill near hinze dam. I would have linked the photo but I forgot what it looked like. its overlooks surfers.
the port of brisbane has heaps of nice spots.
roma street has that roundabout next to the roma street station.
dont know where else really :(
https://www.sau.com.au/forums/topic/32777-scenic-backdrops/#findComment-657615
yar, been there
if i can keep the car nice and clean until the weekend, ill go for a punt down there and take some pix
On a side note, who's doing the detailing, whats getting done and how much is it going to cost?
we called a few places, but ended up going with the closest one
they are D&W Detailers and they work under Fair Deal Cars at Annerley on Ipswich road
gonna cost 200 bux for the full cut and polish and we are getting the insides all done as well (all shampooed and nice and clean)
been meaning to get it done for ages and since woman scraped the side of the car on the garage the other day, it was extra motivation to get it all cleaned up
https://www.sau.com.au/forums/topic/32777-scenic-backdrops/#findComment-657693
shit!
best places are where water is almost perfectly in line with the land
IE if the water rose even a little, it would flood
park car close to water as u can, go out in the water,
hopefully its either nice and sunny, sunset or sunrise
and u should get a nice photo with the contrast of the sun along your car, the reflection of your car in the water, and if on the right angle, it will look like your car is sitting on the water
https://www.sau.com.au/forums/topic/32777-scenic-backdrops/#findComment-658659
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
