  • Replies 49
Posted Images
eBay turbo ending tonight
hey dude
you still got the tailshaft?
Is it for a gtr diff? i'm building a r32 4 door with rb25 box and gtr diff
my number is 0401465502
regards Jordan
Stock Gts-t diff case with Kaaz 2 way inside but I'm keeping tail shaft for now, just selling engine parts so I can sell the running car with RB20 or 25 later.
Thanks,
Daniel
  • 3 weeks later...
Bottom end Sold
Injectors Sold
Modified GTR engine loom still for sale
GTR plenum
GTR throttle bodies
GTR inlet manifold
- Still for sale
