Need to know how does everyone else go for fuel economy?
I went for a drive on the weekend it was a 400km round trip from pannawonica to onslow
I was traving at 130kph all the way not over taking much traffice and used a full tank of fuel
it worked at about 16L per 100km
I just fitted new yellow jacket coil packs and irdium tip plugs set to 1.1mm gap
I have owned the car for about 6 months and its never had good mileage
https://www.sau.com.au/forums/topic/327986-fuel-economy/
don't forget you are pushing a brick through the air. I bet you would have noticed a difference if you'd stuck to 110km/h.
My Skyline did 1/4 of a tank to gosford and back and the rest of it daily duties, stuck in traffic etc. 10.4 litres to 100km.
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334302
i got manual rs4 s2, so NEO engine, and in city/ suburban driving i get about 420-460km, and highway driving, about 500km easily, but on highway im very leadfooted, the onramp onto highway full throttle and a bit here and there on the highway full throttle to clean out the exhaust and heat the oil a bit more.
and im still used to my vw mk2 gti which i managed to get 800km on 50l tank of fuel for highway.
but i doubt i bought the car to be a petrol saver :wub:
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334519
I get about 15/16 from S1 auto. And I live on the mountain. Lots of shorts and up and downs.
I get about 11/12 from a 25g on a steady country trip.
I am sorry, but do not believe you can get 11/12 from a turbo. Even with the better aerodynamics of a 33.
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334632
You bought the wrong car for saving fuel and the planet * Ahem .. load of crap *
LPG kit if your keeping the car for a while.
sausage fuel is only meant for your bbq mate
and its a 2000 neo rs4 stagea
not un happy with it love the car but if anyone know what mods may make a differance in fuel usage i would love to hear about it
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334645
Used to get, as Hugh says, between 11 and 12 in my R33 4dr GTS-t, but on it's last drive to Sydney, when I got my M35, it did better than 9!!
On average, so far, M35 uses about 0.4 more than the R33 did, which I am really happy about.. but best ever, drive back from Sydney when I first got it, was only 10.5 so not the huge difference, open highway improvement, compared to the R33..
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334855
when i drove from tas to qld i was averaging about 10.5 in a series 2 manual
i've got the ecutalk display which shows l/100km once you set up the injector size
most economical speeds were either 100 or 130 (on the dial so about 90 and 120 according to the gps)
eventually i'll get cruise control, its really easy for the speed to creep up
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5334963
Sorry guys, not having a go but "k's to a tank" is not a reliable measure of fuel economy.
This is probably obvious but here's how to calculate your fuel economy:
1. Fill up the fuel tank completely and record odometer reading
2. Drive normally until the tank is close to empty
3. Fill up the tank again again completely and record odometer reading & litres filled
4. Subtract previous odometer reading from current = distance travelled
5. Divide litres filled by [distance travelled / 100] = your fuel economy in l/100km
6. Repeat from step 2
Example: Say your previous refill was at 100,000 km and the current odometer reading is 100,400 km. You just put in 50 litres of petrol. Your fuel economy is:
50 / ((100,400-100,000) / 100) = 12.5 litres per 100 km
Tips:
- Ask for tax invoice when paying as it includes litres filled
- I normally scribble my odo reading on the tax invoice
- Always fill the tank up completely! Otherwise this won't work
- If you're really keen you can record individual economy readings and calculate an average over time...
Hope this helps :)
More on topic, my current readings for the R34 GTT are in the 13-14.5 l/100km range for mixed driving. Bog stock.
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5335761
Or use an ECUTalk and look @ the average economy reading...
:whistling:
S1 RSFV, 3.5" exhaust, DFA, IEBC, S2 I/C, shift kit, ~150awkw: 12.5-13 in the city, better on the open road - providing it stays locked up in 4th.
If your S1 is averaging 16+ on the flat in the city, consider checking your O2 for proper operation.
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5336249
saw 300 for 1/2 tank (disregarding above posts) for hwy @ 110 on cruise control
3 inch auto s2
usually its 150 for the same spot on the guage
should also have added >>> in rain so additional resistance - recently changed o2 sensor (EL Foulcoon)
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5337207
Series 2 (Neo), auto, hiflow, 15psi, Haltech, shitty rich tune, full 3" exhaust, fmic, pod, coilovers, 18's.
Around town I get ~350km/tank, country driving (did a 1300km round trip over easter), 600km/tank (with many jaunts off the clock).
More economical at 140km/h than 110km/h.
Now that I've made my VCT work, I'm getting about another 50km/tank around town.
Edited by bubba
https://www.sau.com.au/forums/topic/327986-fuel-economy/#findComment-5337252
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
