Howdy, I have a series 1 R33 Skyline for wrecking here in Sydney. It's got a few mods listed below:
Rb25det head - approx 120,000ks, good condition, clean as! includes everything from the rocker covers down, no CAS though - $500 ono
5sp Manual gearbox. Good condition, no crunches or noises - $1300 inc tailshaft, shifter and crossmember, or a whole manual conversion kit for $1500 ono
Greddy intake plenum. great condition, includes throttle body adapter - $900 ono
Siemens 770cc injectors + aftermarket fuel rail, speedflow fittings, includes plugs & wiring - $700 ono
Garrett gt3540 / gt35r bolt on turbo kit.. $2100 ono
.70 front, .82 rear, great condition - looks brand new, no smoke or oil residue anywhere, minimal/negligible shaft play
Includes Highmount manifold, 3" dump/front pipe & o2 sensor, braided oil feed line, water lines & fittings, external wastegate w/ screamer, stainless intake pipe to AFM, hose clamps & reducers, everything in the pictures! Can ship it anywhere in Oz
post-35556-1279006742_thumb.jpg post-35556-1279006756_thumb.jpg post-35556-1279006784_thumb.jpg post-35556-1279006794_thumb.jpg
Sard fuel pressure regulator - $150
Z32 AFM + plug. I accidently put a small crack in the side of it :S Still fully working though - could be glued/taped or whatever - $150
Greddy Emanage ultimate ECU, with wiring loom to suit R33 - $800
Exedy HD sports tuff clutch, looks almost brand new - $200
Bosch 044 fuel pump in a R33 cradle, great condition - $150
3" Decat pipe to suit R32, R33, S13, S14, etc - $50
Superspark coilpacks to suit S1 R33 rb25 & rb26, R32 rb20/rb26 - $300
G4 racing coilover set, front & rear. Damper / height adjustable + great condition, no leaks. Suits R33 Gts-t - $650
Monza blue anodised catch can + lines - $80 ono
3" catback exhaust with rear cannon muffler, mid muffler is a bit dented - $250 - pickup only!
HKS turbo timer + Nissan harness - $60
Turbosmart boost Tee, Black - $50
Also have most of the stock parts left for sale:
Engine stuff:
S1 Rb25det engine loom - $200
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $100
Engine Mounts - $80/pair
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
S1 ABS unit - $100
BM44 ABS brake master cyl - $75
Standard RB flywheel, recently machined - $75
Standard sidemount cooler/ SMIC & piping - $80
Ignitor - $70
cam covers - $50
Harmonic balancer - $100
Brakes/driveline:
Front calipers - $275
Rear calipers - $150
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Castor rods with urethane bushes - $80
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 ea
Rear lower control arms - $50 ea
Rear 5 stud hubs - $150 pair
Handbrake drum assembly incl cables - $150 pair
Manaual (4.11) ABS diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Inside:
Floormats, missing 1 rear mat - $offers
Drivers side window switch (s1) - $60
Drivers side window motor - $100
Passenger side window motor - $50
Front S1 door trims - $80
S1 non-airbag steering wheel, pretty worn - $offers
Centre console - $50
Front seats, few cig marks + wear on the drivers seat where you get in - $80/pair
Seatbelts (full set) - $80
Ignition barrel + key - $80
https://www.sau.com.au/forums/topic/328761-wrecking-modified-r33-gts-t-sydney/
  • Replies 86
LNah, yep I can post anything anywhere. If youre keen on the compressor send me a PM
RuthlessRick: Sorry mate it would cost something like $300AUD to send it there by airmail with insurance
please let me know if your willing to split the exhaust manifold
No worries, will do
Hi Mate after the Heater temperature mode actuator located on the driver side of the heater unit. Can uo PM me if you have it?
Cheers
Yup I should have it, PM sent
Diff, cluster, climate control sold
injectors & plenum on hold till sunday
hey mate chasing very top left passanger side grill/vent, the 5x5cm (or there abouts) one.
and what condition is the diff in?
Hey mate, the small vent in the dash pad? don't really want to separate it sorry mate
Diff is sold!
Ill take the handbrake assemlies if comes w/ drums n handle the lot??
yep comes with cables, drums and backing plate- this here:
hey keen on the injectors and rail can you send them to bris and how much let me know 0438298770
Heya, injectors are on hold till sunday, i'll let ya know if it falls through
Cheers
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
