hey guys, its tax time and my money is going towards an alarm (at last)
i went to one place (car accessories installs, tas) and was quoted at $399 for a cyclops p375b
but was advised that i'll probably need to get an actuator fitted to the drivers door to activate the central locking (don't really want to do that) and want $100 for the actuator, relays and wiring
i also went to autobarn where my stagea owning friend works
he says that you don't need to put an actuator in (he did the install into his stag)
but the price that they can do is $600 for a viper alarm (aus standards, black wire, 3 point immobiliser - didn't get a model number tho)
my conundrum is that i'm unsure what to go with
the first place has the better reputation but autobarn has the nation wide backing (autobarn alarm comes with lifetime warranty)
Help please,
Tom
https://www.sau.com.au/forums/topic/328822-alarm-confusion/
1st - check with your insurance company to see if any of the items you can get a hold of meet their standards.
i got a cyclops thingo - met Justcar's requirements
can upgrade later and put on glass bake sensors
also has a std doovie that if the bonnet is lifted whilst activated the alarm will sound
cut 2 keys off your stag key and put in the cupboard at home, use the new ones as entry so you can give the key to the other half if there is one.
no actuators (stags have central locking already)
nothing fancy, just plug and play
beware that it is only a deterrant and if someone really wanted your car they will take it.
but you are then covered with your insurance and it may avoid 9/10 opportunistic thieves from braking into it.
the led i have fitted is a bright blue one so it lights up the whole car, verty visible from outside so it instantly demonstrates that ther is something going on and back off.
Yes i did go through autobahn as well, average service - great install but i only refer to the store i went to. some better and some worse.
Edited by 910trx
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5345725
sounds like i'm in the same boat as you were in
im with just car
both alarms meet the standards
i only need it so if someone steals my car, justcar will pay up
both alarms can have stuff added on as well, and the bonnet thingo
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5345747
im with just car
well the mrs drives it all the time so there is no regard to parking it where its safest, just wherever it stops it becomes locked...
also everyday i see a new post on the site
Car stolen - heaps of things on it
insurance?
no
alarm?
no
$10000 car and its a $400 bit of kit that will in most cases save it
ps: the auto locking thing takes a bit to get used too as well...
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5346827
even easier- bring the car up here..
down in tassie atm, which is why i'm wanting to get the alarm asap
insurance?
no
alarm?
no
yeah, i've had cars with alarms b4, the auto immobilisation is the most annoying
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5347236
car acc installs would be my pick. they are a CAM member and can do a better job of it. that said tell them the car does not need an actuator and that it already has factory keyless entry. that will help.
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5347349
cool, thanks for your advise
whats your opinion of the cyclops alarms?
it'll be the 375b (i think)
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5347817
I sell them :(
basic protection and if well fitted - do the job fine. autowatch would be my pick but thats just me :D
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5348408
I sell them :(
Care to enlighten us a tad on autowatch? Many installers Ive spoken to highly rate them but why dont we see them more often?
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5348427
its not a bad unit. when intalled correctly the only way the car will move is on a flatbed. keyguard is a handy feature. does not matter that you haev lost your keys and someone found them then found your car. its still not going to move.
https://www.sau.com.au/forums/topic/328822-alarm-confusion/#findComment-5349112
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
