Ok I need the SAU guru's to help out on this one.
My car is an R33 gts-t with very low milage in good condition. The following mods/work have been carried out:
- Std Turbo with std boost (5/7 as confirmed by a boost gauge)
- R34 gt-t intercooler (cleaned out)
- 3inch bellmouth dump pipe
- high flow cat (apparently xforce, came with car)
- 3inch stainless system with two big mufflers (also came with car)
- new timing belt (timing reset)
- full fluid service (inc. AFM clean)
- new iridium ngk standard spec plugs (5 heat range, 1.1 gap)
Now the cars runs really well, really stong.
The car has developed the typical br25 flat spot on some nights (keep in mind it is extreamly cold in melbourne at the moment)
The car takes off hard, then flatens out, then feels strong again. This matches up with what I have searched in relation to two things. Not there is no obvious missfire (ie spluttering, coughing)
1. R&R
2. Coils/plugs
Now R&R seems unlikely given the car is running std boost? Is it possible to get R&R is the air is cold/dense enough?
Second I took the coil cover off in the dark and the not one missfire is obvious at any RPM. The car only has 80,000ks and is in exception cond so its not impossible that the coils are ok, Cant find any cracks...
So im confused??? Is it my heat range 5, 1.1 mm gap plugs? Is it R&R?
I must have read 50 threads on the topic but everytime R&R appears is on higher boost and the coils show missfires and actually missfire (ie splutte where mine dosnt?)
Thoughts? :rofl:
im not the smartest of the bunch but just throwing ideas out, i havent read up on this problem either. lol.
maybe try putting it on a dyno? do a self diagnostics on the computer to see if it results come up with anything, i have read somewhere that a TPS can cause this?
get a proper boost guage, with free-flowing exhaust and cooler intake (weather) your boost would be more like 10psi
Id suggest a SAFC to fix the issue, setup correctly on a dyno
well I took it for a drive today, being slightly warmer compared to at night and perfect. pulls strong all the way through. Slight dip at around 4500 but some have told me thats to do with the VVT? is that the case?
Was worried about my spark plugs too, heat range 5, gap 1.1 but given im only running the standard boost I think they should be ok?
PS still only getting 7psi on the gauge (digital) with these mods
RB25 Doesnt have VVT, it has VCT and the default kick off is at 4700rpm
it comes on early in the RPM range and off at 4700rpm
if VCT was dead/disabled your car would be sluggish always until 4700rpm
when it feels flat does the RPM tacho slip to a higher rev range? aka clutch slip
when you light cruise do you notice any different behaviour? aka 02 sensor
thanks for the replies.
Ok would you be able to feel the vct change at 4700? definately no 'flick' of the tacho indicating broad minded personch slip, it is all very smooth, no pops, crrackles or anything odd. Just that 'flat spot'
No problems in cruise. Not I have also replaced the O2 sensor as part of my service and cleaned out the AAC valve.
I have considered the plugs, coils do seem fine and 9 times out of 10 there is not an issue. Didnt want to bring the gap down from 1.1 if I didnt have to but might be required
how cold it very cold?
do you have a real boost gauge ? or the factory waste of space on the dash that happens to resemble a boost gauge?
its gonna make the ecu see more air/denser charge and send it into slack timing look at this picture and youll see what and why .
it runs something around 20-17 then chops it back to like 6 then back up to 14 ish
interesting graph, that certainly wouldnt be helping, wonder why they were so aggressive at that rpm range?
I think its relatively normal on the stock ECU with the mods you have.
This is mine:
Before, and after an SAFC2 tune. Managed to improve the dip as you can see. But its impossible to eliminate without timing adjustments!
And, just so all you "veteran" SAU posters dont get excited, hub dyno, different country.. so dont fret about the "happy numbers" The peak isnt what i was looking at in this instance. More the gain and improvements. :happy:
1. R&R
2. Coils/plugs
Thoughts? :happy:
i had a similar issue, im in hamilton, NZ and we get thick as fog and the temps have gotten down to -4 deg a couple of times so far this winter. my car also has similar mods to you and my car has done around 82000ks. i recently changed my plugs to bcpr6es (i think) with .8mm gap. and it mostly got rid of the problem, so i suspect it could be a combination of plugs and coils (even though my coils look fine). so i am looking at getting some new coils soon. i run high boost all the time, and its around 9psi because of the mods. im suprised that your car still sits an 7psi at full noise, and my exhaust is the factory one with the mid muffler and cat removed.
Edited by R3N3
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
