Yellow Sticker, Rwc, And $300 Fine. (not A Rant)
  • Replies 61
They dont care how many things are wrong of whatever they give whatever they want, Ive been majored and given a fine for just having a pod and cooler and other times for just being to low.
While we're hear, is that your girlfriend in your avatar?
haha, i too would love to know :D
lol, I thought something like that would come up sooner or later. Yay for random babes in avatars! :D
Leigh is was on high st. at high st shops.. remember last time he got me in november. i was washing my car at the caltex car wash on high st. he did laps past then eventually pulled in parked next to cleaning booth and waited almost 30 minutes for me to drive out with him standing infront of booth pointing to park i was liek FFUUUUUU. too bad he didnt find a turbo after ripping my centre console out to look for a boost controller in my NA.. at the time
yeah bad luck i got done too (FU eastside) and they got me for too low. Only at back of exhaust which had recent repair of altercation with winton cliff face. I too got $300 a minor and no rwc.
The epa is a coming....LOL :P
lets hope someone snaps at this fool one day
I can understand if he gets you legitly but to grill people and fine/defect them over nothing, he has a problem.
wouldn't be surprised if he smokes bernie rankins pole daily.
That is because it is at officer's discretion to issue a notice of unroadworthiness along with the defects. I have received defect notices without NOU before. It's just another thing they can add to the pile of paperwork for you to clear up depending on their mood on the day I guess...
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
