Hi All,
I reckon its time to update the lists of wreckers and workshops as they are out of date.
Firstly, we all know the rules NO OPINIONS.
all we need is places that people know and trust. Any negative info can be sent via PM.
This thread will only be open for a few days, so get your suggestions in!
have a look at the WRECKERS and the WORKSHOPS that are already listed (I'm pretty sure there are a couple in there that dont exist any more)
https://www.sau.com.au/forums/topic/329438-update-for-wreckers-and-workshops/
Boostworx change of address
Paint and Body Repair:
Pro Finish Custom Paint
2/20 Famechon Cr
Modbury North
Joe - 0411234992
All Type Crash
1395 Main North Road
Para Hills West
8281 0130
Edwardstown Custom Body Repairs
21 Bennet Ave
Melrose Park SA 5039
(08) 8277 8887‎
G R H Supplies (all sorts of clamps including t-bolts/worms and tools)
167-169 South Terrace
Wingfield SA 5013
(08) 8243 0944‎
Should we maybe run a poll with multiple selections, say at least 5 or 10 votes and they are in?
Or even a + 1 or - 1 system for each place? People can still give a -1 without going into detail, and means its a more fair system. For example, Damos mechanical workshop, i can give it a +1, but 20 people give it a -1, so it obviously shouldnt be in the recommended workshop section.
Just a thought.
Just a thought.
Why? Everyone has mixed opinions about all of the workshops. Its not an endorsement, rather a list of workshops that people may choose to visit.. Leave it the way it is imho
Southern Hitech has a duplicated entry on the page - one from when they were called 'hitech dyno' only and were based upon south road.
-D
Import Compliance Systems
22 Pleasant Grove
Holden Hill
5088
Ph. 0400 945 645
Fax 08 8263 2300
[email protected]
C+A Developements
Hydraulic
Engineering
Race car fabrication
Ph. 08 8264 0844
fax. 08 8395 2970
Also Modbury Automatics are no longer around, Sam shut up shop there a few years ago.
HORSE POWER INNOVATIONS
gtr/skyline guru
0408836384
many of you probably know Brady from his Tilbrooks days
dudes a pedantic perfectionist just what you want in your mechanic
tell him Ryan sent you
Edited by 1400r
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
