1998 Nissan Skyline R34 GT-t
RB25DET Neo Manual
White
105,000k's.
Nismo Bodykit (Aftermarket fibreglass)
Lenso D1-R Rims, 18 x 9 Front, 18 x 10 Rear.
Cam covers painted crinkle red, Valley cover painted black (high temp paint)
Factory Strut Brace
Rear guards rolled
C-West style eyelids
6000k HIDs
Clear front indicators, will come with clear side indicators (not fitted)
JJR Cooling Pro FMIC
HKS Pod Filter – secured with a steel bracket
JJR Coilpacks
Turbosmart Bleed Valve (10 psi)
ISC N1 Coilovers (Height and Damper Adjustable)
Plastic airbox from an SAU group buy
Extreme Heavy Duty steel-backed clutch, no slip.
D1 Spec Oil Catch Can
Split dump pipe
Pacemaker 3” front pipe
3” JASMA approved exhaust
Pioneer head unit
Standard front speakers, Soundstream 6” rear speakers.
Dash lights have white bulbs, but appear blue.
Nismo seat covers
Car made 198.1 rwkw on 12psi, currently makes just over 180 rwkw @ 10psi after Boostworx tune. Now has standard ECU, probably still around the 180-185 mark.
I have owned the car for over 2 years, selling as I have a track project. I don’t really want to part with it, as it has served me well, but its the most realistic option for me at the moment.
Price: $18,600 ono.
http://www.skylinesaustralia.com/forums/Sa...Gt-t280838.html
Trades: none.
  • Replies 49
as if your selling damo.
this car is super clean and always perfect in my eyes.
well worth the coin.
looks a treat and very reliable for a daily.
gl bro it will be sadly missed
such a sad day to see this here...
so many good times with it..
bearly gets driven! but treated like a angel!
good luck mate! and a awsome car for the new owner!
why? im selling the car...unless your offering a trade - my car for your wheels?
if its the former, no thanks, im selling the car, these wheels suit the car.
  • 3 weeks later...
Interior pics please? wanna see where power fc is mounted, if can be hidden? are catch cans illegal?
stick with it though mate, it will go eventually, if it doesnt in next 2 months ill buy it, very nice car.
Edited by stook
The Power FC isnt mounted, it is hidden. PM me if you want more info on it. Catch cans in a closed loop system are legal. ie, as long as they dont vent to the atmosphere, its fine.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
