Store your 26 block away wrapped in plastic and WD40 and go a 26/30, Your GTR has lots of room out back for some good sized rubber.
31 is I believe a rebore of 1mm extra which is the max you can take out of the stock block. Correct me if I'm wrong..
nope, re-sleeved 26 block with open deck spacer plate (sleeves stick out above the top of the block) with an rb30 crank and sr20 rods (i think)
OR, get a RB30 block for $100 and rebuild that, why pay lots when you can get the same for less, lots of 26/30 around to show you how much is to be had for so little.
The Japs need spacers and stuff because they didnt get the RB30, suckers.
+11ty
OS Giken 3.0 litre kit for around the $20K mark. But there are bigger kits than this..........Spool was looking at a 3.2 and a 3.4 kit.
I was reading about it in the latest RB26 Tuning World mook and it sounds like it's quite the beast. But then again, at that price range in better be :(
I've seen a 34R with an OSG 3.0 and sequential behind it..oine of the GTR UK guys had one. Awsome bit of kit. RB30 is ceaper way to go, RB28s (HKS, Tomei stroker etc) are a very expensive option in comparison.
Yes, I still want to build one though
  • 3 weeks later...
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
