  • Replies 291
I was literally just looking at that...
and this... http://my105.com/classified.asp?id=12991
That's Chris Neale's old thing.... didn't it have an almighty smack somewhere????? Mute point anyway, SOLD.
The ex White's R34 (Genuine N1) was a bargain beside those R33's (with the exception of the Tassie N1)....... yes it needed some sorting but as an investment, walked over them. Has some good stuff on it too.
Edited by Marlin
looks nice but what is it engine mods?
55k is alot of money but im sure you get alot of RnD in the car.
ActionDan, here are my calculation so far, if i go down the race/rally rego (which i think is only available in perth allows you to drive to and from events and workshops)
R33 GTR : 10-15k imported
Brake Kit: 5k-10k (there is a might big HKS kit which has 6pot front with something like 370*disc and 4pot rear with 355 disc for 8k + shipping) However there is a set for R35 Brembo which i am keeping an eye on for the time being :(
Suspension: 3k
Suspension arms: 4k ish
Rims: 3k
Cage: 1-3k depends if you go cams or j-spec
then you just need to add tyres and some power and you should have a pretty good setup gtr
Personally i think there is alot you can do to remove weight out of the gtr, i really haven't seen anyone here in aus go crazy with taking stuff out. i have afew ideas i think even with the AWD system you could drop it down to 1300kg ish
(remove abs, aircon, all the interior bits, remove wiring that isn't needed)
Just on a side note, i don't see many people running carbon ceramic disc, is there a reason why other than cost?
Edited by Kaido_RR
Is that the one that ended up on it's side in the trees?
I'd want a street reg'd one, even if i don't reg it at least it can be reg'd later or did you just buy a really cheap import?
Why did you need a big brake kit, how soon were you running out of brakes and why? From what speeds etc, I'm surprised to know that the factory calipers aren't that good if you had some slotted rotors, good pads and fluid plus some ducting?
4k for suspenion arms? wtf?! are you including sway bars in that?
Rims can deffo be had for cheaper.
Brake Kit: 5k-10k (there is a might big HKS kit which has 6pot front with something like 370*disc and 4pot rear with 355 disc for 8k + shipping) However there is a set for R35 Brembo which i am keeping an eye on for the time being :)
Suspension: 3k
Rims: 3k
For sure it's a good whack of money, but guesstimates from what I see on that car:
Clean 33 GT-R 20-25k
Brakes - 10k
Racepace engine - 15-25k with ancillaries
TE37's 3k
Cage 8-10k
Seats 3k
Harnesses 1k
Suspension 5k
Motec ECU and Dash 10k
Ap Peddle box 3k
Fire system 1.5k
Lexan Windows 1.5-2k
CF Bonnet 1k
Terratrip $500
Total near on 100k - plus labour.
There was something about it...... I just can't put my finger on it. It was a loved road car when Chris Neale had it, a showroom pony for Neale's wheels (i remeber he fried the transfer by key-flicking back when it was near new! - $$$$$$), but I think it had a monumental at the Suncoast Classic tarmac rally a couple of years back..... Oldtimers is kickin in....
Haven't bought anything yet just trying to price everything up. If you want a rego gtr you are looking upwards of 20-25k landed and comp.
You can get stockish r33 gtr for around 900,000 to 1,250,000 yen its the complance cost that kills you :)
brakes i want to go big because i got fade wih my 4 pot ap (same size disc as gtr but bigger pads size) on my r33 gtst after 5-6 laps.
Suspension arms i want to replace pretty much everything with ik forumal gear, so i can play with the bump steer and run -3.5 degrees of camber.
Rims just ruff est i will most likely need to go 18-19inch depending on disc size and i want to run min 9.5 front and 19 rear with a +5 offset
You dont have to actually comply and reg it, just get a car that has the potential to be later. If it's imported as race/rally then it can never be reg', if it's imported as a normal car but left as track use only then at least you can legally comply it later if u want.
Only 5-6 laps and you got fade with better calipers, slotted rotors, good pads, good fluid and brake ducting? christ how fast are you going and what temps were you seeing?
Looking around and there are quite a few R33 GT-R's in the 19-22k mark that already have some basic mods and are complied and reg'd already in the country so be sure to look locally too.
Edited by ActionDan
no brake ducting, had N1 master, endless ccrg pads, endless slotted disc, and shell racing fluid. My gtst was not stripped , only had the rear seats out.
I am very hard on the brakes very late. I think what got them was the back straight 200km/hr + then braking very late and dropping my speed to 100
Suspension: 3k
Rims: 3k
So realistically that brings you to 40k and you haven't touched on engine/ancillaries/labour etc....
Makes these 55k well setup cars a bargain in my opinion.
Trust me when I say it will cost you double that if you were to build one from scratch when you want to be at the pointy end of the field....
Just my 2c...
Just my 2c...
oh i 100% agree, i was just saying my cost so far in my build (well just pricing it up atm).
I'm a person who likes to do everything them-self and build to my needs, so buying an already built race car is not really an opinion for me unless it was a euro-race car (that is a different story)
cost me more in the long run but for some reason i like it that way :)
Ahh gtst. Be interesting to see what GT-R Brembo's with all those add ons plus some good ducting would do.
Standard 33 GT-R brembos will be at OK if you have less than 300rwks and doing 3 lap sprints (in a 33 GT-R), although you would have to have decent aftermarket slotted rotors, decent pads and decent fluid with decent braided lines. You'd want to make sure you inspect them thoroughly and bleed them before each track day aswell....
I guess you have to be happy at the end of the day but for me if a car that's already built and had all the money spent on it with proven results at the track, how can it get better than that??? Personally there's no substitute for experience and if the car has been built by a reputable workshop it's worth every cent...
Again my 2c of course.... :D
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
