Hi all im new to the forum,
I have got a 98 model r33 gtst and i am about to change my timing belt, tensioner, idler and all that. im just wondering if anyone has done it before and if there is any tips and tricks for doing it and any no no's? Im doing the 100,000km service bought all the stuff already just gotta do it.
https://www.sau.com.au/forums/topic/330430-help-timing-belt-service/
if your gonna hold onto the car its worth doin the waterpump aswell. think it was 120 from nissan and is behind all that. mine started leaking from tell tale about 120,000 and saves pulling it apart again
yeah iv got the the cam seals, yeah i would but going over seas for a hol at the end of the year so i cant afford to spend much on my car this year other wise i would stick on my t4 turbo.
T4 turbo? eh
Check the timing after you're done with a timing light. Something I didn't when my timing belt was done, and the guy that did my belt didn't know it either appereantly. Someone gave me the tip, went and got it checked. Timing was at 21 degrees, while the RB25DET is supposed to have a timing of 15 degrees.
+1. I have the same issue which is getting fixed at the end of this week. The timing belt was done on my R33 and the timing was set to 10 degrees for some reason. As far as I am aware a manual RB25DET is 15 degrees and an auto RB25DET is 20 degrees.
Tips:...
*Mark the valve timing
*Seal the water pump good
*Make sure cam / crank seals are in 100%
*Check ignition timing afterwards
*Once the new belt is on, turn the motor over 2-3 times
*Locite on the crank bolt and make sure its tight!
*If you can, torque the bolts
*Make sure belt tension is correct
Thats all I can think off atm. :/
how do i suppose to tell how many degrees is mine in?? becoz i just changed my timing belt recently too and i notice my gear ratio is a bit different when i change gears, the acceleration goes up more than usual everytime i step it i guess??
Easiest way is to go to a garage that uses a timing light. Shouldn't be expensive, and done in a matter of minutes. The timing is adjusted through the CAS, and it's really a matter of millimeters, so if you're not sure about what you're doing, let someone else do it. When the timing is really off, it can do some nasty things to your motor in the long run.
sweet, that might be a good idea then, take it to a mechanic to get the timing checked once iv changed the timing belt. This might be a stupid question but is the cas the comp in the car or what? Im not bad when it comes to hand on shit seeing as im a aircraft mechanic and i should be seeing as i do it everyday haha but when it comes to other shit im hopeless haha. Thanks for all your help.
  • 5 weeks later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
