Hi everyone,
Just wanted to introduce myself. I'm Chantalle from Victoria, I'm 21, new to the forum, 1st time driver long time admirer of the Skylines. I have a 2000 Skyline R34.
I haven't had my Skyline for very long, any hints or tips about the R34's would be a great help.
Cheers
Chantalle
https://www.sau.com.au/forums/topic/330615-21-year-old-female-new-to-forum/
  • Replies 45
Hi everyone
I'm Chantalle from Victoria, I'm 21, I have a 2000 Skyline r34, 1st time driver long time admirer.
I haven't had my R34 for very long, but any hints/tips about the R34's would be great.
Chantalle
Hi everyone
Chantalle
Welcome to SAU :P
Hope to meet you on a cruise or something!
Hint: R34's are awesome ;)
Yay! Another 21 yo female R34 owner!!! Go team that! ;)
What colour is your car? Pics? Nice thread title btw (sorry, I couldn't help myself :P)
Here's a tip. They are awesome. But I'm sure you already knew that. That is all.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
