Hi, wondering what the best place to hook the a atuator hose to. Standard setup without soliniod and fmic. Pics are really handy too if u have any. Thanks
Josh
Just connect it to the standard location.
Actually im assuming here that you have one of the 'over the radiator' intercoolers so the stock locations gone right?
I guess it depends what turbo your running. Alot of guys i know like to hook theirs directly to the compressor housing.
But for stock turbo, dunno. Stock location works fine for most people, so maybe in a similar place?
https://www.sau.com.au/forums/topic/330656-actuator-hose/#findComment-5370528
Im not sure where the stock location is, it's not standard intercooler piping, and there is hoses taken out cause of the piping and the soliniod being gone. Right now it's running straight from one ofthe steel pipes that runs accross the top of the rocker cover, usually goes to charcoal canister, not teed off either, just straight from there tothe actuator. Problem is my boost just keeps rising the higher my revs go. This is the setup that was on it when I got it. I am new to these turbo setups. I was thinking of putting on a profec b controller.
https://www.sau.com.au/forums/topic/330656-actuator-hose/#findComment-5370588
Sometimes the boost goes to about 15, depends how cold it is that night. On average it goes 10 to 12, i have a split dump pipe on it also. I have heard that can make a difference. That quick tap idea in the link that was posted seems like a good idea. Maybe i should give that a go. from around the turbo housing, is that where pretty much everyone goes from.
https://www.sau.com.au/forums/topic/330656-actuator-hose/#findComment-5371421
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
