Hey Rush, how r u going? WoW nice work man.
I seen this car in person nearly everyday Parked at ur work place where u took most of the pictures at looks really nice. Didn't knew u were posting it all up here too lol. We have not met even though we work in same street n probably i spot u every now n then driving ur 34 Black matte.
Great work man
  • Replies 161
Great work man
Hey bud,
Thanks for that, where abouts do you work? What's your 33 look like, i might have seen it around also
Oh i am usually at the workshop infront of asianstar/crimesafe.
My dads a panel beater & uncles a mechanic. I just help them with managing all the paper work n stuff.
& my R33 is not registered yet i drive it in the street with trade plate sometimes though but its parked sometimes infront of the shop so if u pass the crimesafe building on ur left u should see it parked on right side. on 29 Meadow ave.
Looks great dude!!!! Especially with the new wheels.
I was in Europe earlier this year and it's a massive craze over there, especially in Germany/Austria. Spotted heaps of Matt black cars, BMW 5series, M5, X5, M3's. A few Matt white cars, Range Rover sport (looked strange) and Cayenne's. The best colour I saw by far was a Matt Green Porsche 911 turbo.... I wish I had the cash because id definetly by getting Matt Green.
Does anyone know who does wrapping in Melbourne?
Z-tune skirts and rear pods, and most likely top secret gtr style front bar with diffuser :P
already have Tein Super streets in there
The Z-Tune body kit is just the front guards, front bar, bonnet and rear wheel arch guards with Nismo Side Skirts and Rear Pods :woot:
So yeah, Nismo.
Top Secret front bar would look nice as well as it gives a more rounded look then the Nismo / Z-Tune front bar, being more straight cut style.
Both are good.
The Z-Tune body kit is just the front guards, front bar, bonnet and rear wheel arch guards with Nismo Side Skirts and Rear Pods :P
So yeah, Nismo.
Both are good.
lol, ok ok, nismo style, lol
yeah i've been eyeing the top secret gtr style for ages, looks porn! pretty exxy though, but worth it i think.
but first up is a JJR black edition return flow front mount!
needs eye lids! needs to be darker, wide body kit and darker black :P
looks good tho! very straight body
U wont get a darker matte black, but at night yhe thing goes near invisible!
Might consider custom makong up some mattr black vinyl eyelids, maybe
The Top Secret front bar sits flush with the front mount intercooler, which makes it look so damn great!
+ the vents and grill are slightly curved to give more of a Stylish look then an Aggressive look to the Nismo / Z-Tune.
Yes I like them both :D So which ever 1 you get, it's a :) from me!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
