So for some reason in the past week or so both my low beam headlights in my r34 skyline have stopped working.
The car originally had xenon headlights, converted to halogens at compliance. Previously been fine but now both have packed it in at the same time.
Parkers and high beams both work. R + L relays in the fuse box can both be heard to click when the lights are turned on but no action. All fuses appear intact (separate R + L fuses) and both globes look ok from a quick macro glance.
With the separate R + L relays and fuses I feel like I am missing a common link between both sides?
Don't have a multimeter at home but might have to source one for a closer investigation I think.
Anyone got any ideas about common problems? Im pretty sure its related to the dodgy conversion which has been done at compliance (ballasts still in place with wiring cut) but am a little bit stumped where to go from here and what could cause a common problem on both sides.
Thanks,
Renee..
Edit: Just to clear up any confusion - I think both headlights stopped working at the same time but not 100% sure as the car rarely gets driven at night. Last time it was driven at night was about a month ago and both lights worked then.
Edited by NAY086
https://www.sau.com.au/forums/topic/330683-r34-both-low-beams-not-working/
man i was just about to make my own thread..!! the other night i noticed my drivers side h/l went out along with the parker..... a few times it would flicker on and off but mianly stay off... only high beams wud work... tonight i was driving along and thought why is it so dark.. then i realised my left side h/l has gone as well.. now i only have the left hand side parker working and high beams (without the right hand side parker working on high beams aswell)
mines an R34 sedan... and mines the same as yours obviously were XENON's but durring comliance have been reverted to plain old lights (not sure if ballasts are sitll there i think my ballasts are gone actually)
anyone know what it could be?
Ok obvious things first
Light bulbs? Yes i know youve probably checked them but still
Fuses? Probably not but im not sure how the lights are wired in 34s so would pay to check anyway
Earth-wiring? Look at the wires that come off the headlights and follow them as far as you can. Most of the time if someones done a dodgy wiring job its pretty obvious or can be made pretty obvious by peeling off electrical tape wrapped around wires etc.
Unlike older style bulbs, the filaments in halogen bulbs can blow and still look ok. You need to check with a multimeter, or connect them straight across the battery to check if they or still ok.
Yep was just globes. Blown like suggested.
Just odd for both to go spontaneously at the same time.
Id say that both going at the same time is like a 1000/1 chance.
It happened to me the other week too. Switched them on, saw them go on (in the garage) drove for 20min, and when i arrived and pulled into a carpark they were both out :s Was just the bulbs. So wierd.
  • 1 year later...
make that 2/1000 man, i just went to the petrol station to fill up before i went to study, worked fine, then i get to the petrol station turn em off... after i pay come back and they both blew at once and i got no idea how to reach the globes..
Whats the easiest way of determining whether or not you have legitimate Xenons and not the compliance halogen ones? On the RHS. the middle light has blown. Not sure what I'm after to replace it. Any help will be muchly appreciated as I need to drive to work at nights and don't want to get pulled over (for obvious reasons).
Cheers, Brandon
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
