Depends on what you really want to spend. NIStune's are around $250 or so, whilst Power FC's around the $800-$1000
NIStune, is just a motherboard, which allows your stock ecu to become completely programmable.
Power FC's are a whole new computer, with hand controller, so you can do 'on-the-spot' programming.
NIStune's are not legal, and neither are Power FC's, advantage of NIStune would be that it is virtually impossible to detect from a coppers point of view, apart from the USB port that is made to allow the USB cable to plug into the laptop to tune,whilst a Power FC is recognisable from its Apex'i casing. Hand Controller is detatchable..but still, if a cop wants to have a look inside your kick panel, you are a sitting duck.
My point of view anyway.
My Power FC cleared regency earlier this week... he took a good look inside the kick panel. :D
+1 however I will clarify that some Nistune boards use the stock consult interface - so effectively there is no way to tell unless one disassembles the ecu housing (and then removes the outer circuit board) ... nistune supports the std nissan consult interface too so there is also that...
tis illegal yes but virtually impossible to spot unless they know specifics.
also, powerfc circuitry fits inside stock nissan ecu housing, mounting it in a stock housing is a common stealth mod
-D
-D
ok thanks I got a r32
The differences are that P-FC has 20x20 maps and Nistune has the factory 16x16 maps. This really doesn't make a difference as the ECU will interpolate between the map points. So really unless you are making huge power like 600+hp and you need to stretch you map to cover a large load range you will not be at a disadvantage, and really an extra 4x4 points isn't increasing it dramatically anyway.
The Big Difference.
Nistune retains Knock Control where as P-FC does nothing to control knock except flash a LED light on your dash. So Nistune will richen you fuel map and pull timing out ignition map if a knock incident is detected but P-FC will flash at you while the engine is pinging it's tits off.
The cost.
Nistune: Board ~$250, Software/Licence ~$200, Cable ~$100.
Really all most people will need is the board, if you want to play (at your own peril) or data log then you can get the licence and the cable. Not sure whether the OBD2 tunable boards need the cable.
P-FC: ~$1000 second-hand, FC-Logit ~$450.
Without FC-Logit you can't do the things you can with nistune and the software.
The Big Difference.
The cost.
Knock control from Nistune is great however you will find that the controlable map points are very limited(up to 4500rpm only) So after this RPM both nistune and PFC will let the engine Ping...just the PFC will let you know about it
The Resolution of the Nissan map is less than the 20x20 of the PFC which gives smoother more accurate response at any power. Especially in the transition onto boost area where high resolution can do wonders to drivability.
They are both good for there respective cost.. but you do get more functionality when you pay more.
What do you mean by this?
the controllable map points are very limited(up to 4500rpm only)
There are two completely different Maps. One regular map and knock map both maps are 16x16. When a the knock count gets about a certain point it switches from one regular to the knock map which has all the 16x16 resolution that the primary map has and isn't limited to 4500rpm.
Are you saying that after 4500rpm it won't switch to the knock map?
yes, the controllable area's of the Map are limited. I'm sure the Nistune guys can fill you in. Since your also in Adelaide...we most likely talk to the same person =) Especially if he drives a mazda 121 with a twin cam.....
Never heard of the nistune not having knock control after 4,500rpm. Probably better off spending the extra money and getting a PFC.
Don't get scared off a Nistune based on a "he said they said" basis. Call Nistune themselves and speak to the guys direct. Nistunes retain knock sensing throughout the rev range ... PFC will just flash a light at you.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
