hey guys,
just after some advise here as iam going to be hiflowing my turbo this week.
i got 2 choices
choice 1: (standard Hiflow)
this is pretty much standard, and they guy said will get me about 250 atw once its done.
choice 2: (PU Hiflow)
this is a bit diff to the standard, bigger housing n such and will get me about 280 atw
The guy said standard is more responsive and will spool at about 3.5, 3.6 and the PU will spool at about 4k revs
my car is a daily and i like to have fun here n there, not a fan of track n calder park n that.
i dont really knw much about turbo's so though i ask the experts here ;P
so which 1 should i got for?
Edited by YF34R
https://www.sau.com.au/forums/topic/331757-advise-needed-please/
What are you asking mate? Which one to go with?
For a daily, go with the responsive high flow. You might get bored of it down the track but its better to go incrementally than for big power straight away, both for getting used to it and deciding when enough power is enough. For a rear wheel drive daily, 250rwkw is pretty well fast enough particularly if power delivery is spread across the rev range. There's not many "traction holding" situations where you'll need more than that. Going straight to the lag of the PU highflow will piss you off if you're used to standard response...another reason to step up incrementally.
what are your supporting mods?
280rwkw with boost coming on 4000rpm is average. Should be sooner than that for that kinda peak.
My GT30 (600hp version) was on 4000-4200rpm and was 270rwkw @ 17psi, would have been over 300 with 20psi and that was with a .82 rear housing, not a machined OP6 (which is smaller)
ask 5 people who have both versions and compare
the std GCG hiflow has been bulletproof for years and should have lots of known users
the PU hiflow is relatively new, different bearing type, and may have other unknown issue, ask 5 users who have one
I've been using the gcg hi flo for 5 years,16lbs of boost daily,no probs. :)
did you fit it yourself or a workshop - if you, how hard, any mods to make it fit, how long if workshop - how much $ to swap
did you send yours away and then get the hiflow back? how long did it take
any install instructions come with it
i got another Question.
say i get an EPA right and i have the hiflowed turbo.
are they ganna pick on and i got get a stock 1 in?
That's the whole point of doing a highflow turbo!
It was sent to gcg,came back in a week mechanic fitted it straight on,it looks stock on the out side,but inside steel wheels and bored out. :(
Oh my mech gave me mates rates, $1585.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
