well if it is an aftermarket one its not much of an upgrade !! i took the front/dump pipe off (im installing jjr bellmouth) and had a look at the exhaust wheel on the turbo and its white/grey and looks like ceramic !!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
