Hi there
I am after some info on the apexi safc, like how much more power would u get out of using one and can u tune the car that much more with one with standard ecu. Sorry for my ignorance I dont understand them that much. I have the following mods if that helps.
Nissan Skyline1997 r33 s2
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
atomic boost controller running 10psi
bov
with standard turbo
thanks
https://www.sau.com.au/forums/topic/331866-apexi-safc/
not sure how much power you have now but with a SAFC you can tune the air/fuel and net 250-280rwhp
aorund 200 now? assuming you dont hit R&R
but if you plan for more mods in the future then get a stand alone ecu which can control ignition timing would be better
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5384682
Hi there
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
bov
with standard turbo
thanks
Most cars with those mods will get between 180 to 200rwkws.
I got similar mods on my car minus the FMIC (only got a SMIC off a 34 GTT) & the coil packs (still on stock ones I think), I got 180rwkw when I got my SAFC 2 tuned at All star garage.
Also my car is a 4 speed slug auto box so theres more power loss at the transmission compared to manual.
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5384734
i reckon something like a Nistune/Mines/Blitz tuned computer coupled with a SAFC is bomb, that way you have the more agro timing maps, and can still pull/put fuel where you need it!!!
why do you need safc when you have nistune?
Mines/Blitz are tuned in jap land and i dont think their suitable with aussie conditions
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5385064
Hi there
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
bov
with standard turbo
thanks
I used to have an Apexi SAFC and an SITC (to control timing) and they worked reasonably well but I would recommend a Nistune chip which will give you much better tuning ability for about the same money. Nistune do not make a chip for the R33 so you will have to use an R32 ecu or other and chip that. Do some searching - there have been a few threads on this topic.
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386329
If you are ABSOLUTELY sure u are not going to do any more mods except raise the boost 1-2psi the safc will be the cheapest and best bet.
U may just get a few extra max kw but the good part is that you can tune out R&R with it and make the mid range come to life
I had an safc2 along with an adj fuel pressure reg and the exact same mods listed above on my 25 and the car felt so much better to drive without that hole in the mid range
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386372
True that ^
But then again it seems pointless. A Nistune board will cost much the same as a SAFC, perhaps a little bit more considering you need the R32 Or Z32 board for an R33. You need a tune on the Nistune or the SAFC, Nistune will be cheaper to tune because it will already have a base image for your car. And then the gains you will get from the Nistune far outweigh those of a SAFC...
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386539
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
