  • Replies 381
Posted Images
lol, i have no tyres left, my rotors are warped, and i have little left of my brake pads..
and i managed a 1min37, i felt quicker..but eh, time to upgrade.
Starlet ran about 10 laps in the 1:31s...theres your goal
Any official timing posted anywhere?
Saw some pretty stock cars running 1.05s and the like on the sheets I saw :)
apparently i ran 1:12 in the starlet :P
Now for October :)
that's because it's an all boys school....
haha CBC grad huh... I feel your pain....
Also, did anyone get photos of my car? it was r33 gtr silver with te37. #29
Im sure i have more, you were out in the quick group with the Willall Stuff most of the day wern't you?
Yeah..... that seems a bit off. How did they mess that up so badly?
That's a bit harsh guys. Without knowing what the issue was, you are blaming the organisers.
If you on't know what the facts are, you shouldn't open your mouth.
Anyhoo,
The SAU SA contingent in this event was HUGE, and you guys walked away with 90 percent of the trophy's. Well done.
Huge Thanks to Shane and Ruby, and everyone else who helped us out on the day, and for making this event over both days, such a fantastic event.
We truly appreciated all the help from your team, and hope that you guys had as much fun as we did.
The SAU NSW team have big shoes to fill for the next one at Goulburn and Wakefield, but having already met the president at Eastern Creek last year, I am pretty confident it's going to be another big one.
Thanks again to all of you.
yep. thats me! are they on your website?
I think you're the one being harsh. Where did I blame the organisers? I merely asked how lap times could have been messed up so badly as clearly Josh's Starlet at the level it's at is not capable of 1:12's. Had I come in and said....
"Wow, that's crazy, the organisers must have been watching TV instead of the track all day"
You would have had grounds for your comment. If you flare up over the smallest little comment, especially not directed at you, perhaps you should listen to your own advice? I don't take kindly to being told to shut my mouth when nothing offensive has come out of it
That being said, thanks for organising a fantastic day, I had a blast as I'm sure everyone else who attended did! Was great to see such a broad range of Skylines out there on the day
Not as yet, will be working through some more tonight and putting them up, I still have a card I havn't downloaded as well, so will get onto them before I crash out tonight
cool. let us know when you get em up
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
