  • Replies 125
THIS VEHICLE IS A SERIES 2 for every1 that has asked me
sydney : it will fit an s15 should be a straight fit ,brakes are in good condition
does that include the cables etc. for the rear handbrake assembly?
and - how much for postage to sydney?
Bump ALL PARTS MUST GO MAKE OFFERS PM ME BARGAIN PRICES ALL NEEDS TO GO
you are still trying to sell your parts but yet i sent you money for the parts we agreed to nearly 4 weeks ago and and i still havent got the parts!!!!
I didnt want to post this publicly but as you are not returning my pm's then this must be the only way you might listen. You said to me on the 31st of August that you were checking on it that day and you will get back to me but you havent and even after i sent you a pm last week you still dont reply.
Either send me the parts as agreed or send me my money back now. Dont fck me around any more, i have been more than patient with you.
Edited by Kiwibob
mate I have replied to you dont say I didnt, I am trying to chase everything up its bad enough me in charge when I didnt have access to the shed, your item was sent out saturday! Thank you .
All PARTS MUST GO NEED THIS GONE
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
