What is your actual price range? Some of those coilovers would start from around 12-1500 and some would be going for 2k+
Dont mind spending around 2.5k but i think anything over is gonna be overkill
+1 for BC's
Not one person that has bagged BC's on this forum appears to be speaking from any real world experience.
Listen to the people who are all very happy driving and racing on BC coil overs (including me)... or just go and spend huge sums of money on some "big name brand" ones that will do exactly the same job.
There are certainly better coil overs out there but BC's are hard to beat in the sub $2000 price range.
Good luck
I put the greddys in over the weekend.
To be honest I'm not amazed with them. they made a huge difference over my old shagged JIC's but nothing amazing.
Maybe because I purchased them second hand they are a bit tired?? had only done roughly 10,000kms apparently but one of the rears seems to have a knock occasionally.
I have noticed that turn in is a lot sharper now and car seems to want to over steer more. car is also flatter around bends and slightly more even. It still gets a bit uneven at the rear around corners so I'm hoping sway bars will fix that issue.
There is a huge amount of adjustability also 32 clicks I think. So I'm still playing with that also
Car is booked at fulcrum on Thursday to have height adjusted, front/rear sway bars, castor bushes, subframe lock and alignment all done
So i'd say go with the BC's and buy new unless you can get the greddy's cheap new (having said that I've never ridden in a car with BC's)
Will let you know how it feels after fulcrum check it out, maybe some bushes are worn out and things will improve.
Edited by stenve
  • 4 weeks later...
just a note when you order them, your R34 GT takes R33 GTST style suspension, so dont make the mistake of ordering a set for R34 GTT.
if you are in no rush and after a cheap set of adjustible coilovers, i will be selling my mixed set soon.
Zeal function fronts 8kg
tein drift HR rears 6kg
Just wondering are the stock ride heights the same for the R33gtst and the R34 non-turbo?
  • Nope 1
  • 1 month later...
just put a set of greddy type s in during the weekend. got them for 1800 brand new. the car feels alot sharper than before, got them on hardest setting all around and they are very stiff but not harsh. very nice and enjoyable, seems to soak up everybit of bump very nicely and at the same time stiff enough to make the drver and espcially the rear passengers bounce up and down heaps. i put them in as it is out of the box without any heigh adjustmentl and they are really low, especially the rear, makes it look like a commodore dump on its ass if you know what i mean. hope that helps.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
