By the sound of it, you'd be best off spending that $1000 on a full service.
Belts, pads, fuilds (diff/gerabox) etc.
Get it reliable before you go chasing power.
exactly what i did. now i know its reliable and whats been done to it so its ready for more power :D
new power fc for bcnr33 is over a grand. Justjap has em for 1499 pls whatever they charge for postage
I should have mentioned that i just finished spending 1000.00 for the major service and changed the clutch for another 1000.00 at the same time.....
getting the bleed valve done this sat and thinking of putting in blow off valves????
sounds good???
sounds good???
Everything is good besdies wasting money on bov. If the stock one isnt leaking then no point changing and spending a few 100 when you will get no gain.
Thanks heaps skline01999.......
i might not waste any money on that than......
if your car is mechanically sound, so no outstanding issues, brakes good, etc, then bleed valve, power fc, and tune.
I dissagree, factory tunning is quite ok for BPU. Without a bucket load of tuning time with the power FC the quality of the tune will never be quite like factory.
As you already have an exhaust and only 1k to spend I would install a really good FMIC add a little boost.
sounds good???
You still got stock ceramic turbos in your GTR?
If so, don't waste money on bleed valve - just pull the restrictor (next right strut tower, there is a solenoid with 2 hose - you'll feel one of hose is bit hard to squeeze, the hose next to plenum, it may have yellow marking) pulling it off will give you safe 14psi.
Also do you have aftermarket (at least 3") front pipe?
14psi + full exhaust (don't worry about dump pipes as they're really good) + Power FC and tune = 240-250kw.
Save up a bit more and do above.
I bought mine for $1,100 with HC off ebay (Brand New). The seller was in qld. Paid another $5 for express postage. Was sitting on my door step the next day
<br />You still got stock ceramic turbos in your GTR?<br /><br />If so, don't waste money on bleed valve - just pull the restrictor (next right strut tower, there is a solenoid with 2 hose - you'll feel one of hose is bit hard to squeeze, the hose next to plenum, it may have yellow marking) pulling it off will give you safe 14psi.<br /><br />Also do you have aftermarket (at least 3") front pipe?<br /><br />14psi + full exhaust (don't worry about dump pipes as they're really good) + Power FC and tune = 240-250kw.<br /><br />Save up a bit more and do above.<br />
<br /><br /><br />
i pulled out the restrictor already....yeah, its got stocked turbo....
i might find for some good cheap power fc's on ebay :P
let me know if u guys have any ideas where to get them from as well :P
<br /><br /><br />
Just keep looking in the forum for sale section theres heaps always selling and yeah just look around ebay and stuff and youll eventally find one for around the 1000 mark.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
