  • Replies 45
Up for sale is my pride and joy, its a r33 gtst Skyline with an rb26. I have spent lots of money on this car over the years, the car has done roughly 5 thousand ks with this engine, only been driven once or twice a month. Would make a great road rego'd track car. I'm a mature owner so the car hasnt been given a gut full, im not in a rush to sell so im not giving it away cheap, it owes me alot and i no what its worth. I'm not interested in swaps so dont bother offering, no tyre kickers or time wasters, i will not be letting anybody test drive car unless they have a deposit. Below are the modifications i could think off my head but will be putting up dyno print out as soon as i can, any questions pm me.
RB26 GTR MOTOR
GTR SUMP
CLUTCH – TWIN PLATE ALLOY (BUTTON)
RB25 GEARBOX
REAR WHEEL DRIVE
COILS- SPITFIRE
DIFF STANDARD
SEATS FRONT RECARO’S
R33 BRAKES TWIN PISTON
GAUGES GREDDY – EXHAUST-TEMP-OIL-PRESSURE & 3 INCH BOOST GAUGE
DECORS 20 INCH RIMS
GATES TIMING BELT
FULL 2 X 044 PUMPS IN BOOT & SURGE TANK
UP FRONT 1200CC INJECTORS
CUSTOM FUEL RAIL
SINGLE 85mm T/BODY
3 “ COOLER PIPING
FRONT MOUNT COOLER- TRUST
SARD FUEL REG
E BOOST 2 CONTROLLER
TURBO TIMER
BLACK METAL MAIN BEARINGS RACE SPECIAL BOTTOM END
ADJUSTABLE TOMEI CAM GEARS
CARBON FIBRE BONNET
4 “ AIR INTAKE WITH K&N FILTER
MOTEC COMPUTER M8OO
TOMEI CAMS 272 DEGREES
TOMEI OIL PUMP
PISTONS FORGED
RODS EAGLE
ARP HEAD STUDS
MAIN STUDS
BIG END BOLTS
CUSTOM MANIFOLD
TURBO GARRETT T 51R
FULL 4” EXHAUST
$40,000
gday mate, you might have more luck in the 'whole car sales' forums other then the parts and accessories forum.
hey mate i just relised i posted it in the wrong forum are u able to tell me how to move it to the whole cars forums as i wouldnt have a clue how to do it cheers
No excessive bumping, and you do not need 2 threads about the same thing.
sorry about the bumping
they are not the same thread they are to different cars one is a 1999 r34 skyline and the other is a r33 1995 model would it be possible to have them seperate again
thanks
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
