MTQ Engine systems are the largest GT dealer in the country. Try them also
As for your problem, I would say very characteristic of valve stem seals in the cylinder head.
that was my mechanics first thought a few months bak, and since then i have completely rebuily the head - new valves,guides,stem seals everything :yes: so now it just leaves the turbo, unless theres ne other issues that we may be looking over?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5398653
Pull it out, strip its housings and check the conditions of its wheels. Turbo is suitable for rebuild only if your wheels are in ok condition with out too much of shaft play. Unfortunately most BB turbos would require a new CHRA for overhaul.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399413
Yes the HKS GT3037 Pro S turbos use the same cartridge as Garretts GT3076R turbo .
The cartridge number is 700177-5007 so you can shop around for the best price on one of them .
Anyone who can remove the compressor jamb nut and the oil inlet ferrule (without bending anything) should be able to strip the cartridge and assess it for you . The advantage of a ball bearing center section is that aside from the turbine end piston ring type exhaust gas seal nothing actually rubs against the bearing housing so unless its had some mechanical failing or the wheels are damaged it may be reusable . It really depends on what the turbo shop has in the way of spare parts .
A .
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399633
Like the guys said, depends where you take it. Since i live in Perth i got Grant from http://www.per4manz.com/ to rebuild my HKS GT2835 PRO S.
The rear bearing race had collapsed resulting in the wheels JUST touching the comp housing. He repacked the cartridge/ balanced at a fraction the cost of a new core. Still going strong.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5400014
I've had nothing but good experiences with MTQ too...call them and speak to then before you talk to anyone else...even people here on the forum...
cheeers mate :rolleyes: would u happen to have an email address or contact on here that i can contact them on?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5404416
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
