  • Replies 52
Posted Images
John - Its her car, I hijacked it, she can drive it anytime, but its not same adrenalin rush as her car.
I wanted to do circuit, but didn't have the heart to tarnish the GTR with a roll cage (yes, she is still special)
Price was okay, but the more I pondered the more the price went up (thanks to other offers that came in, b@stards :yes:)
specs?
do you know if its a close ratio box or just a stronger gearset?
This is from his ad - John Bozman was the driver
Engine
RB26DETT
Estimated Power
500hpATW (@20psi)
Approx Weight
1300kg
Race Results
2003 Runner-up Combined NSW Touring Car Championship
2005 NSW Combined Touring Champion
2006 Underwent Rebuild for Improved Production
2007 Podium Finisher in NSW Championship
2nd in Class (6th Outright) Aust Nat IPRA Championship
Circuit Times
The times below are ex IPRA racing days (Car was running restrictors with a lot less power & less rubber)
1:10.9 Morgan Park 2007
1:45.0 Eastern Creek 2007
1:07.4 Wakefield Park 2007
1:18.7 Oran Park 2007
Engine Modifications
C&B Prepared N1-Block (Nitrited)
Car has recently undergone some major upgrades @ Godzilla Motorsport
Engine Rebuilt ( New Pistons, Rings & Bearings) Only 2 Test Days since
Balanced and Nitrited Crankshaft
N1 Oil-pump
N1 Water-pump
Tomeii Valve Springs & Bronze Guides
Tomeii Camshafts Stage 1 260
Tomeii Adjustable Cam Gears
Tomeii Main & Head Studs
CC'ed Chambers and Matchported
Tomeii Metal Head gasket Kit
ATI 1000hp Balancer
ABE Built Engine
CP Forged Pistons 0.5mm over, Comp 9.5:1
ARGO Con Rods
ACL Race Bearings
ARP Stud Kit
PSI Larger Race Sump with Baffles
Fuel & Induction System
PSI 60L Custom AlloyFuel tank
Twin SX In-line Fuel Filters
Twin Carter Lift Pumps
PSI Custom Swirl Pot
Twin Bosch 044 Fuel Pumps
Turbo Smart 1200hp Fuel Pressure Regulator
PSI ¾"Alloy Performance Fuel Rail
Dynamic Injectors 1000cc Injectors
Garret -5 Turbos
Tomeii Dump Pipes
TRUST High-flow Intercooler
HKS Intercooler Pipes & Blow-off Valve
Electronics
ECM - MOTEC 800
Twin Bosch Ignition Modules
Spitfire HP Coil Packs
Full Custom Wiring Loom (Aircraft Wiring & Deutsch Plugs)
Suspension & Brake
Noltec Custom Coil-over Shocks
Eibach Springs
AP Racing 6 Piston Calipers @ Fr
Brembo 2 Piston Calipers @ Rr
DBA 2 piece, Alloy-Hat on 352mm Rotors
Custom Pedal Ratio for non-boosted brakes (No ABS)
Adjustable Bias Valve
Driveline
OS Geiken 5 speed box
HD Exedy single-plate Clutch
Quaiffe Front LSD 3.9
Cusco Rear LSD 3.9
Custom Single Tailshaft
Chrome-molly Rear-steer Lock System
Chassis Modifications
BOND Custom Multi-point Roll Cage
Fully Seam-welded Body
Nismo Front Cross-brace
Exterior Modifications
Custom Front Bar & Spoiler
Fiberglass Rear Wing
Trust Front Pipe
Custom Exhaust – Nascar Type Side Pipe (Gonzo)
Wheels & Tyres
Rota Grid 18x10 Wheels
Kumho V70A Semi Slicks
Interior
Cobra Evolution Seat
Sparco 6 Point Harness 3"
Momo Sreering Wheel with quick-release Boss Kit
Custom Carbon Dash & Trim
Custom Switch -box
Custom Door Trims to fit Roll-cage
MOTEC SDL Dash
Looks like it is going to be a quick car, fast enough to worry michele?
Im very worried, but for different reasons, the selfish side of me is terrified of losing my pit crew :thanks: and I don't think I will make a good pitb!tch.
You all aren't going to believe this
The dealer may not follow through with the deal even though we have paid in full, he now wants more money (after the sale)
see more http://www.skylinesaustralia.com/forums/R3...78#entry5401378
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
