OK, sorry for the lack of updates, but work got in the way for the past few months, and seeing as it finances the project, I couldn't really say no.
BETTER SAFE THAN SORRY
Having seen a fair number of incidents at the track, and also being a requirement for the race category I plan to enter, I finally bit the bullet and went the full cage. Asking around the racers in WA, one name kept popping up for who does the best rollcages. Brad Stacy. Working for one of the top Race Workshops in WA, and also working from home, I got in touch with Brad, and explained my requirements. Brad was awesome to deal with, and having done dozens of cages before I felt confident leaving my car with him.
The cage took about 2weeks, which wasn't bad considering he was doing it in his spare time. I'm really happy with the end result, and would recommend Brad to anyone thinking of getting a cage done in WA :thumbsup:
http://www.bradstacyfabrication.com.au/
Enjoy the pics
PICTURES
X side bar
Roof X bars
Front view
Rear Cage
Cage Rear Strut
Cage Hoop Top
Cage Hoop Bottom
  • Replies 76
Great work Paul,
Good to see Brad sorted Cage out :thumbsup: .
Whats next dude,
new RB30 :rolleyes:
I'm leaving the engine as is for the time being, makes plenty of power. Likely conversion to E85 fuel though, which should improve response and up the power a bit.
was just wondering about this car just yesturday, how long until it gets back on the track???
Potentially it could go back to the track within about 2weeks, but in order to get everything ready to pass scrutineering it will take alot longer. At least I'm back working on the car again, so progress will be made :thumbsup:
  • 4 weeks later...
just getting my battery nerd on, what are you thinking of using?
you can get pretty powerful motorbike batteries, they already use them in race/drift applications anyway
I'm getting a Braille Battery, only weights 3kg :D
http://www.autocraft.au.com/braille/index.html
bit expensive, but that is pretty light, what one were you looking at? how many cca?
are you looking at the lithium ion technology?
depending on the cca you require i'd say a Deka Powersports ETX18L or ETX30L,
they are a AGM technolgy and should have plenty of power and they could even sit around for 6 months and still start the car.
Give Goodchild Enterprises a call and they should be able to give you a good price on one, even tell them Erik from Bitz sent you
  • 3 weeks later...
stock cams will do 450rwhp wouldnt ever use that much grunt really in a track car, plus you would try to retain vct at any cost possible as it is a very good thing to have while tuning.
very clean car mate did you have a dyno sheet from the engine set up on page 1?
i was also supprised at the weight of the doors as well i have mine off at the moments and there feels like enough metal to make a charade out of them.
how much weight do you think you saved by stripping the wiring harnes out of curiosity?
Edited by kungpow
paul have you disabled the VCT to run the big cams?
looking to do this to mine but cant find out much about it.
Hi Tristan, I've got the biggest VCT cams I could find, Apexi 270degs. I think the VCT is one of the best parts of the RB25s. To be honest you'll struggle to find big VCT cams, so you may be stuck with disabling it.
I do somewhere, I will try and get a copy posted up.
At least 10kgs, I have shopping bags full of it.
  • 4 months later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
