  • 2 months later...
  • Replies 76
Ok, I know I've been slack, but between work and the car there hasn't been enough time to scratch myself let alone keep this thread updated. Anyway, enough of the excuses, time for an update.
SUMMARY OF PROGRESS
Car Re-tuned at Xspeed - 500rwhp at 18psi (ran out of injectors, so plenty more in it when I upgrade to 1000cc's)
E85 Fuel System Installed - parts from Australian Racing Technologies and Aftermarket Industries
Brakes Fitted - AP 355mm 6pot Fronts, and new rear pads
Rear Wing Fitted - R33 GTR Wing, as I'm not allowed to run anything bigger :(
Battery Fitted - Braile lightweight and enough grunt to start the car
Door Trims and Rear Fire Wall constructed - aluminium sheet and a grinder, I'm not sheetmetal worker, but it looks ok
Rear Guards Flares - AutoFX flares the guards for the new TE37s fit
Sparco Navigator Footrest - installed mainly to protect the ECU from getting kicked
Window Net and Tow Hooks fitted
The upshot is the car is almost ready for scruitineering, although it may need a few minor fixes, I'm hoping it isn't too much. The first shakedown test should be in a couple weeks, once Wanneroo Track re-opens (undergoing major in-field works)
Enjoy the pics, ask any questions you want and I'll try and answer them
Fuel Setup
Battery
Fuel Cooler
Tow Hook
Car with new rims (TE37s)
New brakes *drool*
Window Net and Navigator Footrest
Race Driver of the Future (mates son, not mine)
FLAME PROOF
It's only a couple weeks till I take this to get Scruitineered for my Logbook, so I'm trying to do all the little bits which I'll need to pass. So I've spent a fair bit of time doing the front and rear firewalls to make them completely sealed. I used 3mm aluminum sheet where possible, and then fire retardent foam filler for all the small gaps (yes it's pink :whistling: ). Other bits and pieces include mounting the 2 1kg fire extinguishers and the padding around the rollcgae bars.
Enjoy the pics
PICTURES
Rear Firewall
Flame Retardent Expaning Foam Filler
Front Firewall
Side Intrusion Padding
Roof Padding
Fire Extinguisers
Awesome read mate, it's been a while since you started, I bet you're having a ball knowing your getting much closer. Keep it up mate.
Yeah, it's starting to get real. Filling in my CAMS license for a Provisional Circuit license, and only a month of so from my first competitive race :thumbsup:
  • 4 weeks later...
FINISHING TOUCHES
So my car had it's Logbook signed off on Friday, which means I'm not too far off getting the car signed off for racing. I also submitted my Provisional Clubman Circuit license, completed the online test, and did my Observed License Test on Monday, so should have my competion license soon :worship:
The car had its first shakedown at a Motorkhana event on the Sunday, and then on the Monday I was at the racetrack. All seemed to be going pretty well, other than the front guards rubbing, but then the brakes seemed to have developed a massive vibration, enough to shake the entire car, so it kinda stuffed up my day at the track a bit. Still the engine and everything else performed really well, so in general I'm happy.
I've since investigated the vibration, and I think it may actually be a stuffed wheel bearing, so looking at fixing them soon.
Due to the weather looking a bit dodge on the weekend, I finally got my ass into gear and fitted the perspex windows. I think they look awesome :D
Enjoy the pics
PICTURES
Back on my P's
Perspex Windows
Ready to Roll
A Day at the Office
Great read mate. Funny thing about the wing not being able to be any bigger then BAM! the evo wing is a shopping cart on steroids lol. Cant wait to see some action shot from its track days :)
The evo is setup for WTAC, so isn't competing in my category, hence the reason it has so much aero :thumbsup:
  • 1 year later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
