WTF? RB25DET's are factory 9:1 comp ratio
You are gaining nothing by putting RB26 gear in your RB25 block. Unless you have a spare crank lying around that you need to use. The stroke is slightly more but the extra 100cc is not going to do FA for torque or power.
The reason I will use rb26 crank is because I have the block and enginehead but no crank,rods or pistons. So instead of buy an rb25 crank and then mount a crank collar on it would cost almost as much as an longnose rb26 crank. If 100cc doesn´t do anything then I wonder why so many high performance gt-rs from japan is stroked to 2,7?
Almost every aftermarkets pistons for rb26 is 8.5:1 but If the rb25 head is smaller cc maybe it is possible to get 9,0:1 then :)
^ umm but how do you have a RB25 now, without any innards?
It's not even 100c, its like 60 or something.
9:1 will be fine, pretty standard for anyone rebuilding in this day an age considering fuel advancements over the past 10 years+
Also just use GTR rods, they are fine for over 400rwkw and less than half the price of eagles
I bought a head cheap for about 1 year ago. The I found a block now to. So I will use them to build a complete engine of. A std rb25det cost about 2300Aud here and Im gonna change so much anyway so I think this would be the best way to go :)
You can buy a RB25 bottom end for next to nothing my friend... the head is the most expensive part.
Then just GTR rods ontop of that and you are set. Would be less than $1000 AUD easily. Not sure there you get 2300 from when you already have the top end :)
Beats buying a new RB26 crank IMO, unless you know the RB26 crank you are getting is fine but the cost to check, and if it needs repairing then its almost neutral.
Im from Sweden and It´s alot more expensive with parts here. I have searched for a while for a bottom but didn´t find someting we don´t have so many parts here. So I had to order the block from England. I want the long oilpumpdrive to so I think the rb26 crank would be fine.
Edited by Turbo_Knuff
The collar can be purchased and fitted for about $200 total. Being in Sweden might make things hard but there's always international shipping
Don't think that getting a second hand rb26 long nose crank is the best solution, because IMO it's not.
Often times on a second hand crank you will see where the oil pump drive has rounded away on the edges of the flat even on the long nose. A collar with international shipping will be under $100AU easily, and then you know the drive is 100% OK after fitting.
Edited by James_03
DO NOT shave the head more than just a surface because it'll stuff up your cam timing and possibly make the timing belt go slack.
Just order some custom 9.2:1 pistons. You won't be disappointed!
Sorry but that's the biggest load of shit I have ever heard. You aren't going to take enough off a cylinder head to have that much of an effect on the timing belt.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
