hey man just had search but i couldnt reli find what exactly i was looking for...i just need a quick answer...is it a big job to put a rb30de bottom end onto a rb25de? n will help me run higher boost more safely?
plz plz plz
The correct CR will help you run higher boost safely. so while u got the RB30 block apart, replace the pistons for lower CR, just grab a set of VLT pistons, they will be fine. if you read thru the rb30 conversions in the "forced induction performance" section, you will notice it isnt sucha big job.
if anyone is planning to do this, i have the stock R33 intercooler and piping for sale atm, for $80 ono. just pm me, its all in very good condition btw.
Don't be fooled gents. its not only the compression factor, but the piston itself, the N/a pistons are not Hyperputectic. therefore, even with low boost pressures, after a while you will melt a piston.
By all means, do this upgrade! turbo is 100% better effecient power, than most other mods. But do plan to change your pistons over in the near future.
Not really, my car ran fine for a over 50,000kms and as far as I know is still running fine without ever being cracked open to change pistons.
Melting pistons is from a poor tune, you can do it with any engine
the cast pistons will not tolerate the higher combustion temperatures associated with boost.
of course a good tune will help keep detonation to a minimum and the correct supporting modifications will ensure oil temps and water temps are kept low, but eventually the pistons will give up the ghost.
an example is my good friend who has a famous AE86 drift car here on the gold coast.
He had a stock 4AGE bluetop (bigport) bottom end which has the smallest rods, crank and gudgeon pins of all the 4AGE's and it took 6 months of punishment from a HKS GT2510 at 13 PSI pushing 150 kw at the wheels out of 1600cc.
It had a great tune from Adam from JEM and had all the supporting mods like a alloy radiator, great intercooler, big fuel system and oil cooler. The water temps never got above 82 and the oil never about 90 - 95. Eventually, the pistons gave up. But it goes to show that a motor can be pushed to nearly triple its factory power and still last for a while given that the correct supporting mods and great tune are applied.
Side note: I have read that the turbo RB30 pistons with the twin cam head will result in a 7:1 CR. too low
hey i just though i would go back a little bit and add something in, in relation to drilling the oil return line into the block a way of getting around this would be to buy an oil cooler and run the oil lines from the oil filter to the oil cooler to the turbo out the turbo then into the engine and around agian, this way you would have the best oil going to the turbo and you wouldnt have to worry about drilling holes in the block, and as a bonus it would be even easier to return to stock if needed
  • Like 1
13psi in a 10:1 is asking for trouble that would have contributed to the death of that engine...I owned a blue-top as well and managed to melt the piston without a turbo.
under 8psi with stock pistons will see a reliable engine that won't need forgies and will live a long prosperous life.
ive got vacuum hose running straight from the compressor nipple to the wastegate actuator and its natural boost is .8 bar.
i do have a bleed valve in the line but its completely shut. i might delete this as it may still be causing a boost increase.
If you've got an RB20 turbo that's normal though, the actuator I put on my highflow from an RB20 was 13psi straight on the actuator, no bleed valve.
Grab one from a series 1 R33, it should be nice and tired and give about 6psi
Absolute bullshit, my series 1 25de had the oil return just above the sump blanked off which simply unscrewed to fit my return line fitting. The same as the water return and oil feed, the only thing I had to source was a water feed which I t-pieced from a heater hose. Piss the rb20 crap off, accept a 25det stock turbo as a minimum.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
