Specs
1990 skyline hcr32 Gts-t
-bn blister widebody kit (much lighter than stock skyline)
-r34 front conversion, r32.4
-sunroof
-5spd manual
-120,000ks
-reg till june 2011
-rwc can be suplyed. will need front upper control arm bushes
-drift gauges. water/oil pres/temp
-white face cluster
-drift deep dish stearing wheel.
engine:
- Hi flow turbo (less than 1500ks old) rebiuld by hypergear have recipts
- Tuned ECU- Remap. (CEFFIE tune)
- HKS pod. (and stock airbox)
- 42mm alloy radiator
- Kakimoto exhaust. ( not loud) had driven past heaps off police. they dont even look
- FMIC
Driveline
- Tein HA coilovers- hieght and damper adjustable
- Hicas lock bar
- extreme HD clutch.
- Front and rear cusco strut braces
- Work Vs xx
18x10 -12 offset rears (245x40x18) potenza re-01 (90%)
18x9 -4 offset front (235x40x18) (100%)new
the rest is stock. well kept engine. I just did a service. had its 100k service done in 08 and has done 16,000 ks since then. Im the 2nd owner. Iv looked after it well.
car is in great condition. Starts every time. never missed a beat.
always service 5000ks. (done last week) see pics. Lol
-Motul 4100 turbo light
-Drift oil filter
-Nulon anti freeze anti boil coolent
-NGK bcp6es .8 gap
making around 200kw at the wheels with plenty of room for more.
reason for sale
I want a motorbike.
so will part trade for
fzr250 zxr250 ninja cbr250 hyosong gt250. Or a cheap daily.
BAD
will need front upper control arm bushes. (probly be done by the time anyone buys it)
bonnet needs painting.
few large dints in roof. Just need to be poped out.
price: make an offer. Might get lucky.
$8,000 with out wheels
$10,000 with everything!!
https://www.sau.com.au/forums/topic/334145-widebody-r32/
Specs
-sunroof
-5spd manual
-120,000ks
-reg till june 2011
-white face cluster
engine:
- FMIC
Driveline
- Hicas lock bar
- Work Vs xx
-Drift oil filter
-NGK bcp6es .8 gap
reason for sale
I want a motorbike.
BAD
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5424435
sorry about the post above.....my i phone wouldn't let me type anything......had to wait to log on elsewhere
dont know how to delete the useless post of mine above...
I have zx600 96 model......12months rego ....after market pipe......
i ride this on my "L" legally here is S.A.....your aloud up to 660 on Learners bike now
very good condition.... i have picks but dont have the cord to post them, i can send pics through my i phone if your interest PM your number...
i tried to pm you mine but i cant cause im new here..
i use the bike everyday for work....starts first go everytime... even in the freezen cold..very reliable
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5424466
There is a fair chance ill kill my self on that. ha. but send me some info. Sounds interesting.
Thanks.
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5425638
That is porn! If i can sell my 34 and I dont like the trades I have been offered I could be very keen unless your keen for a a 34 4 door and cash my way??
http://www.skylinesaustralia.com/forums/Fs...or-t335606.html
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5432552
swaps welcome.
Cheap car plus $$ my way
Or nice car up to $5000 cash your way.
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5432715
If you were in NSW i would be interested in swaps for my pulsar (http://www.skylinesaustralia.com/forums/00-Pulsar-Sedan-nsw-t333927.html) if you were keen. Looks like a pretty tidy car.
Just a tip I'm not sure on the restrictions for bike riders in vic but if it uses LAMS rules you need to be careful of which 600's you look at, some comply but a lot dont. That's how it is here in NSW anyway.
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5432795
hey man what mods are done to the motor? what size is the turbo looks bigger in the photo? cheers
The turbo is bigger (its been high flowed). Its hard to measure but it runs stock rb20 housings, closest comparison would be the gt2860rs
Motor? its stock unopened. List of mods are up there ^^^^^
https://www.sau.com.au/forums/topic/334145-widebody-r32/#findComment-5442904
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
