Ps... Anyone out there willing to lend me a Crain to get the block out?? Will sort a deal forsure!!
As a few may know I messed up my timing belt. Heads off, #2 claimed both intake valves witch snapped off... And hacked up the piston top... Boar seems good at this stage... How's the safest way to clean the shit out?? Top that piston and blow it out? And what do i need to know about piston removal?? Am I getting 6 freshies? Cheers boys!
Edited by chef_stagea
https://www.sau.com.au/forums/topic/334164-removing-pistons/
Got pics of the piston? At this stage I'd be taking the motor out mate, you're gonna have to take off the sump to gain access the crank/rods so you can remove the rod bolts and then push the piston out through the top. Then I don't think it's gonna be as simple as dropping in a new piston. You've got clearances to worry about, etc. Looking more like rebuild territory from the info you've given. That or a replacement motor
yeah without pics of the severity of the damage, I'd say Luke's on the money
you'll need to remove every bit of debris out and if there's anything caught between the cylinder and top ring land, good luck getting it out.
Also, any damage to the bore (below top land) will cause you grief unless addressed......you'll be surprised how even minor bore damage can affect the top comp ring
Yeah ok... So basically rip the engine out n go from there... Why is it not possible to just replace the piston? I'll put pics up of the boar tomorrow. 1st thing I need to do is drop the auto box off!!
I've already brought a new head. Getting cleaned up and port and polished too. So I'll avoid new engine. For that reason. Money and rego/numbers bullshit.
When you say rebuild what are we talking.. Full bottom end sent away?
There's all tiny bits of valve everywhere... So there would be shit down there!
The guy I got the head off has the bottom end ( cyl seized) maybe I should grab that for parts???
I'm not 100% clear y I can't just change the piston top to a stockie... Or just not Gna happen?
Winner winner, chicken dinner
Alot of questions there Adam.
Firstly, to remove a piston from the top, you need access to the bottom end, hence why engine should be removed.
If there are bits everywhere, more than likely the above will need to be done.
If the guy's bottom end siezed, don't touch it!!
Hopefully that answers most of your queries
EDIT: If you remove the piston in question and it looks OK once you've cleaned all the shit out, there maybe a case for using it again......if the piston is damaged however, changing just one piston may also be a possibility. Without sighting anything though, we're pissing in the wind unfortunately.
Ok don't want to confuse the situation here...
My piston #2 is hacked badly! Not usable at all. I can get a good 2nd hand one for 100... More than stock i no so I'll get onto that...
Engines coming out. f*k re-assembling in the car,
I'll get some pics for you all tho.
you really should balance the new piston the to other 5.
Since you are going to have the engine out i would whack some rings and bearings in it and perhaps give it a light hone. It will cost you a couple hundred more and then you will have a fresh bottom end.
whats wrong with being centered Dan??? i am contemplating rebuilding my old RB25 and well that has the same as what adam has done to his.....piston-valve loving.....should be a good way to learn more about the beloved RB25
yeah, as Dale said Adam.
If your pistion is totally stuffed, I'm guessing it's also had an effect on your cylinder......which will then need to be bored along with the other cylinders (plus new oversize pistons & rings).
Even if the bore has not been marked by debris, you'll still need new rings for that second hand piston and at the very least, have it lightly honed (and ridge removed if any to avoid top ring damage) otherwise the rings for that cylinder won't bed in & therefore won't hold compression or control oil blow-by.
sounds like a perfect candidate for a 30 bottom end!
would love to damo but i just cannot afford to go down this track...
truth needs to come out :thumbsup: the belt that was in there was only 10k old!!! but i allready had it off b4 i knew!! anyway
yes i post on an iphone sometimes, it wont let me select the screen so i have to use a special item tool thing.
here some pics anyway...
i think ill just f**k this engine off, the 34 neos obviously RWD... is it a matter of putting the stagea sump etc onto it and off i go?
im going away friday, but will let you know about the crain and stand. but that would be amazing!
the boar doesnt look too good in that pic, bit it feels smooth.
Not as simple as that IIRC, don't think a RWD can be converted to AWD
would have been even cheaper if he let an experienced person replace timing belt....
lesson learnt?
Most definitely!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
