i know we dont agree to breaking the law on this forum and all that but i would risk it, i did for two years, stupid now i look back at it (having a VK 308 with a holley sticking out the bonnet then to my r33) and pure luck that i was not stripped of my licence, but watever, why did you even buy it if you DONT WANT to even use it as it was built, i dont think there is any downgrade threads here either so good luck
https://www.sau.com.au/forums/topic/334296-r34-gtt/#findComment-5416675
