So i just got my first skyline
It has no remote central locking and no alarm system. While i'm at it, i'd like remote start.
I've noticed a huge difference price wise between the main brands (e.g. viper etc) and other no name brands on ebay, but the specs seem to be the same.
Has anyone had any experience in the cheaper alarms? I dont need a state of the art alarm but i dont want to have somthing installed that gives up after a few weeks.
any thoughts?
cheers,
https://www.sau.com.au/forums/topic/334327-which-car-alarm/
Viper #1
also with the amount of threads of cars getting stolen
dont buy a cheapo if you value your car
really? so you are happy with an alarm that only drops the starter?
autowatch for me thanks. drops 3 ckts requires a proper installer to fit the thing and its oz stds - something the viper is not.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5429888
  • 3 weeks later...
all comes down to who installs it, no matter what alarm system it is the install is the main issue because you get lazy installers who dont solder and leave wires exposed so be carefull who you take it to.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5461260
I've also been looking at the ebay ones compared to ones in autobarn. The ebay ones (for $45) have the same specs - sometimes more - than the ones in the stores. Might just buy a cheapo one and see how it performs, not a huge loss if it packs in on me, car is always locked away so can always get a expensive one.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5474784
any thoughts?
cheers,
remote start is highly illegal in Australia (ADR rules suck)and a defect
so is the turbo timer function of some car alarms
and check your insurance, cause some won't cover you unless it is an AUSTRALIAN approved model
some shops won't install ebay crap, and a how about a warranty ?? shop local, buy local for support reasons
don't try to install it yourself
a guide for approved car alarms and other info
http://www.nrma.com.au/documents/brochures/crimesafe-car.pdf
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5481707
Another option is GPS tracking systems, I fit them for www.intellitrac.com.au, basic tracking systems starting from $299 fitted might be an option for use. If you need more info feel free to pm me
Edited by gelousi
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5485055
Hi guys,
I'm the Australian Government and we don't want anyone to have unique or interesting cars, because, you know, only hoons drive nice cars.
https://www.sau.com.au/forums/topic/334327-which-car-alarm/#findComment-5485305
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
