Ok so I'm about to replace the standard BOVs with an aftermarket blitz item on the weekend.
Just wanted to know if i need to get anything else before I take the front bar off and have a crack. Swapping them over is pretty straight forward but I wanted to know whether anything special is required to replace 2 BOVs with 1.
BTW I know the factory GTR BOVs are good enough as they are. This is my car and is a personal choice that I'm making so if you dont have anyting productive to add are just going to flame me for putting on an aftermarket item then dont bother.
Thanks
Pls find attached a pic of the Blitz item
The Blitz item you have seems to have the correct flange on it so its a matter of unbolting the old ones and putting the blitz ones on...and then blocking off the plumback pipes...
PS: i'm not against aftermarket BOVs at all but to me the blitz ones and the apexi ones are probably the worst sounding bovs of the lot...
sweet thanks for your help man.... i sorta like the blitz item... heard one on a 32GTR the other day and i liked it :D
will let you know how I go over the weekend
i have the exact same unit on mine, u should also check that the pistons can be moved if u ease off the top adjustment nut.. mine was clogged with oil/crap and jammed so im currently cleaning the whole unit
u can block off the return pipe with whateva, but i have found turbosmart does making blanking caps in the correct diameter, probably best way to go, $16 odd bucks
ps. what u doing with ur stock as i might be interested in returning mine back to stock
cheers man.... any idea which mm the diameter is? i think it might me 19mm.... do u know if supercheap or any of the other auto stores stock the plug??
yavuz tuned mine as well, didnt have any issues with idling before the tune however have read others have.. the blanking plug is around 30mm i think, will measure mine when i put the bovs back on tonight
thanks mate
I guess, thats what I was asking
Seems like I will take it off and plug the pipes up
my bad, i assumed u had both bovs, i guess you can tee piece the hoses to the bov and cut a plate to bolt into the empty space or get an adapter for the single bov so it plugs straight into the rubber pipe
I'm also going to do this with my greddy type s but I'm going to plumb it back to fix the idling issues. Making a block off plate for the second bov and the g reddy type s has 2 vacume nipples so I can put them both on for the extra vacume :ermm:
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
