Custom Glass Carbon Fibre R33 Projector Headlights Group Buy!
  • 4 weeks later...
Just a note for the guys who want to run twin HID's. 2 points. Firstly you cant flash people if they cut you off, are your mates etc. Secondly if you have your low beams on and switch to high beams, the high beams will take about 20 seconds to come on. I wouldnt be doing it. I have low/high HID's in my truck, but they use a common bulb, so i only have the flashing problem, which is a real pain.
Ill be in for a set of series 1 lights. And an idea for the parker/indicator problem, why not run dual colour LEDs not much dearer and it wouldnt take much to design a cct that takes both inputs and changes the voltage to run the LEDs. If people are interested i can have a go at designing a cct to do it and price it up.
Could you explain the dual colour LED thing a bit more? I didn't even realise that was available!
So it is one LED that depending on an input can be a white parker, or a flashing orange indicator?
You would run the normal inputs ie when parkers are on the LEDS are white and when the indicator is turned on the LEDS change to orange and will flash because youll still be using the original indicator cct. (use both inputs as per a normal setup)
There is two types of BI colour LEDs, 3 pin types which are just basically two LEDs built into the same discreet package or voltage depended ones which change colour depending on input voltage. Depending on what type you can get in a White/orange combination will determine what kind off cct youll need to drive them properly and youll need to set them up in such a way so that they dont load down the flasher can and make them flash fast.
Ill give jaycar or RS a ring on monday and see what they have available. Ill also have a go at designing a cct to drive them but you might be better off getting hold of an electronics engineer (might be one on here somewhere?) theyll be able to knock something up no worries. (Im only a techy not an engineer)
cheers shaun
Very interesting! Definetely something to look into then. I'll let the boys at SPINTO know and see what they think.
hows this coming along?? i'll be looking for a new set of headlights soon... i'm trying to hold out and see of these can come through in time.
I have been waiting for a reply from Richard at Spinto regarding this project due to some news I came across on the Supraforums:
http://www.supraforums.com.au/forum/showthread.php/67723-Important-announcement
SPINTO will temporarily be halting ALL sales after the 26th of January. We will be working in the motorsport industry and won't have time to manufacture more parts. We will be closing down the supraforums SPINTO section until we are ready to open again. We should be back in 2013.
To our customers who have been very patiently waiting for our plastic headlight kit. We apologise, we did not foresee this event.
Looks like this project may never happen :(
there are some mobs in the states that do hid retrofits and i know of one specifically that has projectors especially for rhd cars.
So this might not be dead but just needs a change of approach.
i think first thing first is to agree on a design (for both s1 and s2) then we can approach someone to see if they can mass produce it.
just got into the office so i'll be busy for a little while but i'll see what i can track down.
For what its worth it might be worth while to track down a large number of used headlights with crap glass to be used as the basis of replacements.
further to what i was just saying... this thread went down in flames... but its a good start... it has a customiser and some parts suppliers listed... we might be able to get something usable out of it.
http://www.skylinesaustralia.com/forums/topic/349128-altezza-lights/page__st__20
Why not start a group buy for replacement glass covers? That would be awesome! Any glass moulder/manufacturer could do it and I'm sure there would be hundreds of customers!
Still no word back from SPINTO so I dare say this aint going to happen.
Sorry guys :(
Will definetely look into some other option though.
My plastics are really "new" still, not faded or yellow, so i was more interested in the "sweet LED and HID" part of this deal, but the glass should be good too. How different would glass look compared to excellent condition/polished plastic? Obviously it wouldn't fade over time, but i'm wondering if it's worth the cost :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
