I currently have a GT3040R .82 on my rb20 which i believe is a GT3082R?
I’m currently running 21psi and plan to screw in another 4-5psi, is this still in the efficiency map for this turbo?
at the moment the engine is making 10hp/psi and has made 371rwhp @ 7300rpm
at what point would you go a 1.06 rear housing or would you go a GT35R with a .82 rear. what is the difference from the obvious?
what are these turbos rated hp wise with the 3 different rear housing options?
what would the response/lag difference be between each combo
for a reference im making 5psi @ 4300rpm and ramps hard to 5500rpm making 17psi
what would be the next step with the turbo, my goal is another 50-70hp
Thanks Luke
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/
On a RB25 i made 270rwkw @ 17psi with a GT3040 (600hp) in a .82
If you get a GT35, it'll be laggier, simple as that. Its a larger comp wheel so its going to be slower.
Given then 600hp GT30 should do 330rwkw, you need more boost.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422243
yes will have more lag but just how much, 500rpm, 1000rpm for same boost.
330rwkw on a 25 or 20 and at what psi
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422279
How do you know its not coming into another area of efficiecny and so on where the power gains are more than 10hp/psi?
IMO much below 24-25psi and the turbo isn't really in its happiest place given i should have been running closer to 20-21psi on a 2.5ltr
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422362
the next step up is the GT35, in 0.82 form it will do 350-380rwkw.
that is going to be very laggy on a little RB20, you will have ~1000-2000rpm of full boost before you have to change gear again. if its just to get the number is it really worth it?
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422364
Nitrous, E85 - two much better ways to get that little bit more power
Or just alter the dyno setting, for 40hp I'm not sure the need for the hair splitting...
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422370
but will it do another 100hp.
Probably, if your motor can.
Whats done to your motor? Your coming in fairly late with only 5psi by 4300, I know the gibson RB20 had powerband between 6 and 8 yet a 1:1 bump on the static CR and a 3 psi drop in boost saw it with usable power between 4 and 8... MASSIVE difference.
Tell us more about your motor.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422443
40thou over size arias pistons, spool rods, ported head, 264 cams 8.5mm lift, 8.7cr. high mount 3040, rb26 intake and throttles,
changing intake to 80mm tb and new plenum on half standard runners to make a little more torque. cam gears set at odeg atm.
720cc injectors, toda light weight flywheel,
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422464
Leave the throttle, try get the gears dialed up. For interest sake I would also try dialing them with the stock intake cam.
Your motor sounds like it can make the power, just need to push the turbo into efficiency along with the tune to match. 25PSI and a good dial on the gears should get you the power Ash is talking about (30rwkw) if not more IMO.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422601
Nismoid the Garret turbine maps actually show the flow rates of the 0.82 GT30 and the 0.63 GT35 as having similar maximums though IMO the GT30 0.82 is the better map , these are with the T3 flanged GT30 turbine housings BTW because the 30 and 35 both use them .
Not my project and don't think I'd build such a top endy RB20 but to each their own .
Now there is another option in the GT3082R family and its what used to be called GT3040 in HKS speak .
What it is is same deal as the Garrett GT3082R/GT3040 but with a 50 trim rather than 56 trim GT40 compressor wheel in it .
My old HKS list shows its good for 20 more PS/Hp than a GT3037S/GT3076R 56 trim .
I have a compressor map of a Garret large frame plain bearing GT4082 which uses this same compressor wheel and it shows the the maximum airflow rate at the bleeding edge of about 57 lbs so potentially 570 Hp if you go by maximums .
This is in a 0.58 A/R GT40 compressor housing which is crudely speaking of a similar size externally to a T04S o.70 A/R one , maybe a smidge smaller but port shrouded .
It may even pay the OP to look into Mitsubishi turbos because they tend to use reasonably big wheels in smaller trims than Garrett does sometimes and that could pay off when you want power over as broad a range as possible .
BTW what does the OP want to do with this RB20 ?
A .
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422747
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
