I currently have a GT3040R .82 on my rb20 which i believe is a GT3082R?
I’m currently running 21psi and plan to screw in another 4-5psi, is this still in the efficiency map for this turbo?
at the moment the engine is making 10hp/psi and has made 371rwhp @ 7300rpm
at what point would you go a 1.06 rear housing or would you go a GT35R with a .82 rear. what is the difference from the obvious?
what are these turbos rated hp wise with the 3 different rear housing options?
what would the response/lag difference be between each combo
for a reference im making 5psi @ 4300rpm and ramps hard to 5500rpm making 17psi
what would be the next step with the turbo, my goal is another 50-70hp
Thanks Luke
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/
On a RB25 i made 270rwkw @ 17psi with a GT3040 (600hp) in a .82
If you get a GT35, it'll be laggier, simple as that. Its a larger comp wheel so its going to be slower.
Given then 600hp GT30 should do 330rwkw, you need more boost.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422243
yes will have more lag but just how much, 500rpm, 1000rpm for same boost.
330rwkw on a 25 or 20 and at what psi
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422279
How do you know its not coming into another area of efficiecny and so on where the power gains are more than 10hp/psi?
IMO much below 24-25psi and the turbo isn't really in its happiest place given i should have been running closer to 20-21psi on a 2.5ltr
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422362
the next step up is the GT35, in 0.82 form it will do 350-380rwkw.
that is going to be very laggy on a little RB20, you will have ~1000-2000rpm of full boost before you have to change gear again. if its just to get the number is it really worth it?
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422364
Nitrous, E85 - two much better ways to get that little bit more power
Or just alter the dyno setting, for 40hp I'm not sure the need for the hair splitting...
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422370
but will it do another 100hp.
Probably, if your motor can.
Whats done to your motor? Your coming in fairly late with only 5psi by 4300, I know the gibson RB20 had powerband between 6 and 8 yet a 1:1 bump on the static CR and a 3 psi drop in boost saw it with usable power between 4 and 8... MASSIVE difference.
Tell us more about your motor.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422443
40thou over size arias pistons, spool rods, ported head, 264 cams 8.5mm lift, 8.7cr. high mount 3040, rb26 intake and throttles,
changing intake to 80mm tb and new plenum on half standard runners to make a little more torque. cam gears set at odeg atm.
720cc injectors, toda light weight flywheel,
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422464
Leave the throttle, try get the gears dialed up. For interest sake I would also try dialing them with the stock intake cam.
Your motor sounds like it can make the power, just need to push the turbo into efficiency along with the tune to match. 25PSI and a good dial on the gears should get you the power Ash is talking about (30rwkw) if not more IMO.
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422601
Nismoid the Garret turbine maps actually show the flow rates of the 0.82 GT30 and the 0.63 GT35 as having similar maximums though IMO the GT30 0.82 is the better map , these are with the T3 flanged GT30 turbine housings BTW because the 30 and 35 both use them .
Not my project and don't think I'd build such a top endy RB20 but to each their own .
Now there is another option in the GT3082R family and its what used to be called GT3040 in HKS speak .
What it is is same deal as the Garrett GT3082R/GT3040 but with a 50 trim rather than 56 trim GT40 compressor wheel in it .
My old HKS list shows its good for 20 more PS/Hp than a GT3037S/GT3076R 56 trim .
I have a compressor map of a Garret large frame plain bearing GT4082 which uses this same compressor wheel and it shows the the maximum airflow rate at the bleeding edge of about 57 lbs so potentially 570 Hp if you go by maximums .
This is in a 0.58 A/R GT40 compressor housing which is crudely speaking of a similar size externally to a T04S o.70 A/R one , maybe a smidge smaller but port shrouded .
It may even pay the OP to look into Mitsubishi turbos because they tend to use reasonably big wheels in smaller trims than Garrett does sometimes and that could pay off when you want power over as broad a range as possible .
BTW what does the OP want to do with this RB20 ?
A .
https://www.sau.com.au/forums/topic/334874-gt30r-vs-gt35r/#findComment-5422747
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
