As long as you get your colour code right, the colour should match well dood!
The rest of your paintwork is good so it won't stick out at all...
Heaps of good panel and paint places around Perth. We (family) have used "bowra panel and pain" in Balcatta...
Sweet....ill have to gget a propper quote...what about faded paint??? i dont think its faded at all...
Waddya mean? That last sentence doesn't make any sense...
Are you saying you want matte silver instead of gloss silver?
But I thought it doesn't matter how good it is, mixing paint over 2 seperate times will ALWAYS going be a little bit different.
Therefore, if you were to spray your door, they'd blend it to your front fender and rear quarter.
Because if you don't, under different sort of light, you will be able to see the contrast between your front fender (one colour), door (one colour), rear quarter (one colour).
Although sometimes people can never tell, but since you know it's there, you will be able to see it everytime :D
I have a little rust spot on my right door, and i was wondering if i had that door re-sprayed would the colour match exactly? or would i need to get the whole car resprayed to get a perfect match?
for a little rust spot its probably better to touch it up rather than respray
i had this problem with my old r33 gtst, i made the mistake of getting just the door repaired and painted, the fresh coat of paint and clear coat stood out soo badly (car was silver KL0 ) that i ended up getting the whole car resprayed....then sold it few months later, waste of money lol
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
