I am after a good picture resizer program that will work on Vista Ultimate 64. For use with downsizing large images for posting to teh internets with lossless quality.
Prefer something that can batch process and even handle RAW conversions to JPG. I have CS5 and ACDsee Pro, but wont something lite n' easy for rough and ready batch processing.
I use a Canon 40D...
Photoshop is good, but doesn't do batch resizing.
I use Faststone. Batch resizing, watermarks, borders, renaming, ect ect. Not bad for a free program!
True that,
but I guess all my pics will be different sizing when they are done.
A friend of mine takes photos for nightclubs, he would have to use what you said.
There will be over a few hundred photos a night and to edit them all in 1 go...
"Batch resizing, watermarks, borders, renaming, ect ect" will come in handy for large amounts of pics.
Then all ready to upload to the nightclub website.
Adobe Lightroom is what I use...as I do weddings it is very good for batch processing, crop, resize and basic touch up. I now rarely touch Photoshop as a result unless I'm making a picture from scratch or massive PP.
Does RAW and a variety of conversion options.
edit: also comes in 64bit flavours.
Edited by mickey
Yeah LR is awesome - I do 80% of my PP in there
Must say I've done some tests on an 800px photo and even on high LR wont sharpen it as much as Irfanview
(When you have a photo open in irfanview Ctrl+S is sharpen, in batch you can specify a value from 0 to 100 - suspect a normal Ctrl+S does "20")
What do you mean Photoshop won't batch resize?!
1. If your photos are portrait orientated AND landscape orientated, seperate them so that one or the other doesn't get enlarged.
2. Create an action in photoshop to resize to XXXXXXXX size.
3. File --> Automate --> Batch
4. Run the batch with the resizing action.
5. Laugh.
As regards to sharpening, LR only uses ACR's engine to sharpen. Its really mainly only for capture sharpening. There is also on LR3 the option to enable capture sharpening, plus sharpen when in the "Develop" tab, and then an option when you export for "output sharpening".
I normally use PS to sharpen if need be with either smart sharpen or using a High pass.
To do a high pass, duplicate layer --> Filter --> Other --> high pass.
It will be a grey box. Turn the radius down/up so that you can just see the outlines of your image (it will look for edges i've found) so maybe around 2.0 or something. depends on your photo.
Press ok. Change blend mode to overlay/soft light/hard light.
i use VSO image resizer. mainly because its accesible from left click menu in explorer. dunno about raw etc
Yeah this is just what I was looking for - easy as & does RAW. Had a simliar left click one on XP, a windows powertoys app. Though can't get it for Vista-64.
Works very well and lossless quality for big images... Haven't tried LR. for anything I want to tinker with I'll still go via CS5
Thanks for the help :down:
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
