Hi gang, i just had a custom plenum nade for my 34 neo and ariel left the iac valve off as he advised me to check with my tuner first to see how he would prefer it mounted etc. as its off already and no plates have been welded, i was wondering if its possible to tune and allow the car to run/idle normally with it removed? If not, what will be a side effect of not running one?
i've read that the 34 setups are diff to 33 and most neo boys used 33 iac and tb. if i'm unable to tune it without the iac then whats needed to fit and get the 33 iac working. do the plugs fit or they need to be rewired ? does it matter if its from s1 or s2?
any help much appreciated :D cheers
If you remove it how will the car idle? The throttle body is closed so there will be no source of air!
Definitely need an idle air control valve. Whether you can use a different one depends on how they are wired up, I imagine they are just a duty cycled solenoid much like an injector, so as long as the tuning software allows adjustment of the gain factor for the valve you should be able to really use anything.
Feel free to correct me if I am wrong though.
it is best to have it or you can put an adjuster screw onto the throttle body to hold the throttle open slightly, this is a bodgy way as there is no adjustment for idle up during air con, lights on etc
put it in an easily accessible place that looks neat/ hidden. you will need to be able to run the hose from it to the intercooler pipe just before the throttle body
hey fellas, cheers for the response.
will be running a nistune so i guess it would be best to have it installed. i'll look into fitting a r33 iac instead and hopefully i can find some information somehwere. i have a/c still and would like to keep it.
nistune will freak,
but like guilt-toy said generally it is no issue, map sensor based ecu's dont really care either way, but iac equiped car will always behave nicer especially on the street..
if its nistune use the r34 iac setup remote mounted.
Hey trent, cheers for the info. can you enlighten me more on remotely mounting it.. does this mean i have to block the rear of the valve with a plate and tap a feed to the top of the valve instead? ariel mentioned something about this and said to consult with my tuner but i'm finding it so hard to get in contact with unigroup to get some answers..
RB25 throttle bodies have the adjustment screw allready there.
Just to quickly clarify, AAC (Auxiliary Air Control) is the hose that goes into the intercooler pipe to feed extra air into the engine when the throttle is shut and IAC (Idle Air Control) is the hose from the heater that feeds warm air into the engine when warming up, correct?
Question, how is it that a lot of cars from factory run fine without AAC (Such as a JZA80 Supra). Is it because they are map sensored so it makes it easier? I have tried pissing my AAC off back in the day but the Microtech simply hated it even though it is MAP sensored. So what's the go?
Edited by PM-R33
yeah map sensors dont actually get effected by minor airflow pulses etc so generally dont try compensate... hence rock solid idle.
You can even drill a small hole in the butterfly to help stabilise the idle.
but like previously mentioned its not all that nice for everyday streeters that need pwr steer, a/c etc load compensation.
Only reason I wanted to piss it off back in the day was due to not wanting to run the extra hose when going to the Plazmaman plenum. Now it doesn't really worry me since it is allready set up. It was mainly a "neater" option to not run one at the time :happy:
Edited by PM-R33
will just end up getting the plenum modded to fit the IAC, would make life alot easier :D
why is the iac mount missing? is it an old version?
the ones on the website are like the one i had in the shop, had a bolt on position for the stock IAC.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
