Wrecking whole front end of an R32, all components except the long engine for sale, post here with what you're after.
Aftermarket Stuff:
R32:
3 .3 - 3.75" Cat-Back Exhaust: $400
Mechanical 1.5 way LSD + housing and half shafts: $950
N1 Headlight (driver's side): $200
Universal (for any car):
Short-shifter: $150
Sparco Rev Fixed Back Bucket seat (average condition, has tears etc) $200
3-Point Harness: $50
MOMO "Race" Steering wheel with Nissan Boss kit: $250
GReddy SM Integration Guages + sensors + control unit (water temp, oil temp, oil pressure): $650
3-Layer Copper Radiator: $200
AVS Model 6, 17x9 +36 (pair): $400
Lightweight Jap Wheels (17x8.5 +35): $250
BBS RS 17x9 +20: $1000
Work Meister 18x9/10: $2950
Stock Parts
R32 GTS(t):
Suspension/Steering
2x Front Sway Bar - $50ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
1x Front Passenger side Lower Control Arm - $60 -- PICS
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
1x Rear Toe Rod (hicas) - $50ea
Misc:
2x R32 2dr - Doors - Silver - $300ea
2x R32 Gearbox - $500
2x Indicators: $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
R32 GTR:
Front Grill: $150
R33:
Standard VLSD with housing and Half shafts: $300
R33 Lower Control Arms - $200pr
S13:
Located in SA near Mitcham, can Post Anywhere
https://www.sau.com.au/forums/topic/335162-the-get-me-back-to-japan-sale/
  • 3 weeks later...
Do you still have these? If so can you please send me a couple of pics! Thanks mate.
Adam
hey mate, sorry, dont have them anymore.
Alright this is an updated version:
Aftermarket Stuff:
R32:
Stock Parts
R32 GTS(t):
Suspension/Steering
Misc:
R32 GTR:
Front Grill: $150
R33:
S13:
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
