Hey guys
trying to source some interior pieces to get it back up to scratch, please pm with any parts available and prices,
R32 dash in perfect nick no bubbles
R32 dash cluster (working and around 190xxx want to keep it as close to real as possible)
R32 dash cluster surround (with all buttons attached)
R32 steering wheel in perfect nick
R32 steering column surround pieces
R32 stereo surround (prefer out of late model with grainy surface)
R32 gearknob with shift pattern
R32 side steps in perfect nick
R32 floor mats in perfect nick (may be hard they are 20 years old)
R32 rear seat (bottom piece)
R32 door trims in perfect nick
so if anyone with wrecking wants to offload most of their interior shoot me a pm!
cheers guys
Kyle
https://www.sau.com.au/forums/topic/335326-wtb-r32-interior-pieces/
i have a complete gtr interior out of a 32 i stripped today minus front seats and steering wheel if u want me to ship i can arrange has a 320km tacho
text 0431741272
located adelaide but
Iv got the Dash Cluster Surround here (top half complete with all switches / buttons in good working order and Very good condition.)
(Bottom half) Clock was sold a while ago, hole for immobiliser light
also have steering column surround peices and 1 side step in gd condition will check which side
pm me if interested
  • 3 weeks later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
