Hey guys
trying to source some interior pieces to get it back up to scratch, please pm with any parts available and prices,
R32 dash in perfect nick no bubbles
R32 dash cluster (working and around 190xxx want to keep it as close to real as possible)
R32 dash cluster surround (with all buttons attached)
R32 steering wheel in perfect nick
R32 steering column surround pieces
R32 stereo surround (prefer out of late model with grainy surface)
R32 gearknob with shift pattern
R32 side steps in perfect nick
R32 floor mats in perfect nick (may be hard they are 20 years old)
R32 rear seat (bottom piece)
R32 door trims in perfect nick
so if anyone with wrecking wants to offload most of their interior shoot me a pm!
cheers guys
Kyle
https://www.sau.com.au/forums/topic/335326-wtb-r32-interior-pieces/
i have a complete gtr interior out of a 32 i stripped today minus front seats and steering wheel if u want me to ship i can arrange has a 320km tacho
text 0431741272
located adelaide but
Iv got the Dash Cluster Surround here (top half complete with all switches / buttons in good working order and Very good condition.)
(Bottom half) Clock was sold a while ago, hole for immobiliser light
also have steering column surround peices and 1 side step in gd condition will check which side
pm me if interested
  • 3 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
