uncle duncan and i went halves in a front cut
basically we kept the following parts
pannels/engine gearbox/alternator and power steering pump
eveything else is available
so if you want anything give us a yell or send us a pm
some ideas of what i have left over
all dash things
all the stuff behind the dash
ic and hoses and bov's and return pipe
the rad support
fuses ect
front hubs
steering rack
ect
anyway flick us an offer and ill see if we have it
prices start from a 6 pack to a couple of hung for the bigger stuff!
cheers
Peter C
0448468884
located lower blue mountains sydney
https://www.sau.com.au/forums/topic/335785-left-over-r32-gtr-front-cut-bits/
PM me with prices for dash vents left and center please as well as the glove box to 2298 west waratah nsw and would you happen to have the drivers and passengers window glass without any scratches i dont know what comes in a half cut these days
vents + glove box = 100 bux and 20 for delivery
i do have the window glass, 100 bux for both ( you would haev to pick em up as i would not like to post them)
i do have a eo but its a tad chopped up 30 bux
front lip spoiler is long gone.. very hard to find
