I have by chance downloaded an 808 page complete R32 GTR Workshop manual.
Now as I don't have a GTR yet it will only be used in the month's to come.
This PDF file zipped is 21Mb, and came from
http://www.lancer-evo.net/manuals/misc/r32.zip
I used my works Internet to pull it in about 10 minutes, it would have been over an hour at Modem speeds.
After my last post with the R33 Parts diagrams, there is no way I can get this to everybody so some one may want to host it :worship:
I can send small sections as needed, but most ISP's will stop that size doc.
Hope we can all use this.
Regards
Mark
https://www.sau.com.au/forums/topic/33596-complete-r32-gtr-workshop-manual/
  • Replies 44
This link came from the Skylinesdownunder forum and is 136Mb in size.
It is a RAR file of the fast disk, Nissan manual, part numbers etc.(use wrar330.exe to uncompress)
I have downloaded it and installed it on my XP machine, but it does not work fully.
This could be due to the 1999 date on it and that it needs Windows 98.
http://forums.skylinesdownunder.co.nz/show...ght=nissan+fast
There is a URL http://194.149.66.28/auto/gr.rar
Run this thread then select the URL, right click save target and wait.
The uncompressed version is 336Mb. I have started to debug why it fails by getting the VB416dll files. Hope someone cracks it, meanwhile I will carry on by putting it on Win98.
Hey guys at least its free, I don't beleive in making fellow Skyliners pay for good knowledge.
Good luck.
Mark
Got them both - thx muchly for the links.
Over 56k (yawn).
A bloke oin EBAY got caught with this - he paid over $300 for a supposedly genuine hardcopy of the GTR manual, that was obviously just a print of this PDF.
Now, all I need is my car and I can start to fiddle!
Hi Cobra-Mark
I to have down loaded it on to XP machine and sound to have the same VB problem. did you install it as the read me file said to do for windows.
I was going to try loading the other 3 zip files and installing them with the .exe as it said to do if you are using dos. the 4 or 5 files are together in one DIR.
All I am getting at the moment is a window opening with 3 or 4 options and exit. exit is the only thing that works.
Keep us posted on what u try and if it works
Cheers
Sherlock_NZL,
I have given that a go, but it requires the vbdll416 library, as th einstall does not even run without a small error at the end.
Still on course to prove it this weekend.
Will let you know.
Mark
Cobra_Mark
I have got the Training manual  that teaches you and shows you how to work the parts part of Fast using XP, that's as far as I have got at this stage.
Cheers
Can you send me the training manual to [email protected]
Hi Skyline33
Yes I can do that
You must have a working copy of Fast I guess, If you want to know how to use it.
mine doesnt work if I could have a copy please.
What size email can you take
What year are your files. mine are mostly 1999
What operating system are you using
Cheers
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
