This is possible with VMware's Thin App. Basically it allows to you create a portable version of any application you want to. Start off with a clean windows build, run Thin App and it pretty much records the install process and packages it up into a standalone exe (it has sub folders with other required files).
But of course this comes with a price - and possibly only available in a bundle with other VM software/licensing...
http://portableapps.com/ is your friend :(
I work in IT, use it all the time.
VM ThinApp is good, but is really an enterprise solution that costs the world (we use it), AppV from MS is another, but again, enterprise solution.
well you'd do something like that if you didn't have installing privleges on a workstation and you wanted to run unsanctioned apps, god only knows how many people do that here aaah.
You are right, and it works for me. :cool:
Edited by wonkotheinsane
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
