anyone out there want one.
just got a price for one and it was stupidly expensive.
so blow that i will get one get a mate to mold it and sell em for a proper price.(i dont consider it a rip off cause i will be copying a copy of a copy of a copy gedit)
me figures that it will be worthwhile to do if i have a minimum of ten people who want one
so basically who wants one
cost will be the purchase and the cost or ten molds. all up id say 100 each for your lip.
or am i the only silly kunt who wants on
it ok if you want one for your gts i wont give ya to much of a hard time(just jokes)
pete
https://www.sau.com.au/forums/topic/3362-r32-gtr-vspec-rear-lip/
  • Replies 82
I am definitely interested in a GTR copy front grille!!!
If you make one I will buy one...at the right price obviously..
also if you make anything for the front of my gts-t 32, eg. nice looking lip etc...or copy of a GTR front bar I would be interested as well..
The front of my car looks ****!!!
Edit: its' 002 NVS, like my number plate says, bockshard or wateva ur nick is...:)
wouldn't mind the lip for the back as I have the GT-R rear spoiler.
As for the front grille, has anyone considered cutting the bonnet to fit the grille but inserting mesh instead of the grille? Would look good on my car as it has mesh down the bottom.
lol so far its me, meggala, inark and u looking for one of them. I think its a D-Speed eurathane bottom lip, which is designed for GTS/GTSt's n bolts straight on.
fatz, sorry for the hijack... is this what you are selling?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
